ken0la
- Apr 13, 2007
- NWestern ON
- NONO
LOL welcome to the bent subframe club! Part of yamaha ownership... Just keep bang'n and add it to the job jar for the months without snow...
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
ken0la said:LOL welcome to the bent subframe club! Part of yamaha ownership... Just keep bang'n and add it to the job jar for the months without snow...![]()
Just poor design, a least the apex could hold up to a few good hits.
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
....unless you have grizztracks braces! I hit a massive tree with mine and never moved the subframe. The A-arms needed replaced but the subframe is straight.
I likely just jinxed myself
yamajammer76
- Apr 6, 2005
- Black Hills, SD
- 2024 Arctic Cat Riot 600 1.75
Sno-Xr said:Im with beenba.....Ive pounded the crap out of my xtx and know the subfame has been tweaked back and forth. I dont plan on replacing mine.
Yep my 2012 XTX is sort of the same as well. I hit a rock last winter which made one side closer to the shock on the top A arm, but it seems to move back and forth. Sometimes it is off more then other times and sometimes you notice the opposite side is a bit off then after a rough trail it goes the other way. It's crazy!!! The skis are still about the same distance in front and the spindles have pretty much the same angle so I just ride it. It still handles well. I'm not going to mess with it unless it ever takes a big hit again and comes in contact with the spring.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
How do I go about bending it back
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
09nytro
But that's not fixing the subframe , all it's doing is bending the upper a-arm back so the shock is centered .grizztracks said:
I wouldn't do that with your z-bros. Front end , that's just me !
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
It won't bend the a-arms unless you get carried away. I've done several of these and what it will do is bend the rear a-arm tower back into place. You'll be surprised how easy it is to bend the frame back. After realignment it will eventually move back unless you reinforce the frame. I just did another one last weekend.
toyota4runner
- Jan 23, 2012
- Manitoba
- '09 FX Nytro
You question the all mighty Grizz? The Viper side has impaired your judgement I see09nytro said:But that's not fixing the subframe , all it's doing is bending the upper a-arm back so the shock is centered .grizztracks said:
09nytro
I just don't see that working , it didn't on my subframe when I bent mine , so yes I'm questioning grizzly on this . It also depends on how bad it bent too !
09nytro
I have a nytro in the shop right now with a bent subframe , the bottom tube is push in and the lower arm mount is bent also , the plate just in front if oil pan has a buckle in it to , so that little trick wont work on this one !
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
- presdwr.spaces.live.com
Take a pry bar between the upper and lower a arms and pry it back to place. Works like a charm and still holds.
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
Another thing is I have had 3 nytros. I have bent subframes on two of my three. After adding a roest full skid plate to a fixed subframe and on a new machine out of the box I have never bent a frame again. The skid actually stiffens the frame and prevents the easy tweaks.
toyota4runner
- Jan 23, 2012
- Manitoba
- '09 FX Nytro
I was only joking lol. It definitely depends on the severity of the damage. For the record, I had a right side spindle that was almost vertical from crossing train tracks, and was able to get it back to within reasonable spec to finish out another 1200 miles and get me through the season. The main damage was to the rear lower box and the bottom circle plate. This was purely a temp fix until I could pull my subframe and properly straiten and weld in Grizz gussets. Also there was zero damage to my control arms before and after the pry bar
Sno-Xr
- May 3, 2005
- Clio (Flint), MI
- Nytro
09nytro said:I just don't see that working , it didn't on my subframe when I bent mine , so yes I'm questioning grizzly on this . It also depends on how bad it bent too !
There definitely are exceptions to the rules, but its worth a shot before you run and throw a bunch of $$ at something that will ultimately bend again. I have about 8000 on my 09, and have watched the spring gap go back and forth like many others have experienced. And when I get the time and ambition to strip the front end down, I will be adding gussets. But until then, I'll ride it and enjoy the cash I still have in my wallet.
