Jackshaft bearing clip
I removed & resecured my snubshaft. My offset shrank to 60.62 with 1.3mm washer.
Removing 2mm from shaft & replace 1.3mm shim with a .5mm shim. This will put me @ 57.82mm offset.
I know what you are saying. I ended up switching to the gates redline 8jp equivalent. They rate it for 300F before the rubber breaks down vs the 200F the Yami belt does. I have had great luck with them, ran one belt to 1800 miles and wasn't light on it. Have not blown one yet.
Any side effects with the 40R4313 G FORCE belt? Rpms up or down vs 8jp?
I did not notice rpms change vs the 8JP. I did notice that I seem to have more belt dust than the 8JP ever did but I don't know if that is due to the fact I run the redlines far far harder than I ever could the 8JP.
