Joined the yamacat winder crew today
What size vacuum cap for the air inlet for the rov delete? I brought the tubing to Napa and it was 5/8", went to put it on tonight and slid on and off.
Is 3/8" the correct size or 1/2?
Half inch
OK i understand the winders have had a list of problems,but asside from the couple problems you have had to work on,how do you like the power and handling? Is this winder all stock? How does it pull other sleds in your group,and mostly how do you like the power and ride?
Power is excellent, and the rest is dependant on how much time you spend on learning and setting up your sled. If you buy and just jump on, you might be pretty happy, but you also might hate it. If you learn what it likes and doesn't like and tune it in, good chance you will be really happy.
Most people in my group have sidewinders, the others have polaris, because I spend time with my sled, it pulls everybody
it has zero traction from below 40, once it hits 40 it pulls like no other sled.
It handles about the same as an old triple triple compared to the twins of that day. I love it for what it is.
Since my side of the state turned into an ice rink this week i got some parts installed on the sled today. Did the cvt side today, those three bolts on the caliper are a pain and drained the engine oil tonight. Will work on the chaincase tomorrow. Any writeups on removing everything from the chaincase? I looked at rocker dans thread and I know there is something I have to do with the reverse actuator but don't know what it is yet.
Also filed my brake pads to reduce the squeek. A quick yard test proved it to work pretty well
Well I got christened this weekend with an anti freeze puddle on the floor. Worried that it may have been a gasket but Knapp said look at the fittings and there it was.
Gave the fitting a quarter turn but it was pretty damn tight
