Perfect!!8.7 grams
0.307 oz
Red grease
Centrifugal force will cause the grease to work it's way to the furthest radius allowed. More RPM causes it to push outward, then when letting off to lower RPM's where the engine has the harmonics and the grease will move around somewhat again.Gave this a little thought...I'm not exactly happy on Tapp's vagueness. But I suppose I've (and others) made a mountain out of a mole hill.
Once the splines all meet it's basically wiping out any additional Grease into the snubhub.
To me, common sense tells me to use barely enough just to cover the splines with a decent film.
Again I'm not exactly sure what any more additional grease that gets wiped off the spines will do for us?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Kinda how I figured it would work too. Wonder how liquefied the grease gets when at temp...
I myself figured more grease is better from that aspect.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I completely understand what you're saying.Centrifugal force will cause the grease to work it's way to the furthest radius allowed. More RPM causes it to push outward, then when letting off to lower RPM's where the engine has the harmonics and the grease will move around somewhat again.
So if the Snubshaft is partially or completely full of grease that would leave the grease on the splines no where to go, as far as outward centrifugal force trying to push it into the Snubshaft.
More better? Idk....
Ya, I used every bit in the package.Kinda how I figured it would work too. Wonder how liquefied the grease gets when at temp...
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
It will remain relatively stable until it nears its dropping point. Here is a great example.Kinda how I figured it would work too. Wonder how liquefied the grease gets when at temp...
Here is my before and after on my 2017 Winder.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Wow pretty big difference. Didn’t make any difference on mine.Here is my before and after on my 2017 Winder.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Those are the videos kolenko is sharing. Did you use his grease or the TaPP grease?
Then you may have not used enough grease or have bad clutch parts. I had bad rollers in one. Didn’t help until I fixed the clutch.Wow pretty big difference. Didn’t make any difference on mine.
I used his grease. I do have 2 more to do. So maybe some just won’t work and some do. Not sure why some are really quiet and some are not. I’ll know more after I do the others.Those are the videos kolenko is sharing. Did you use his grease or the TaPP grease?
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
Good point. Interested to see the difference when you do some with the TAPP greaseI used his grease. I do have 2 more to do. So maybe some just won’t work and some do. Not sure why some are really quiet and some are not. I’ll know more after I do the others.
If they would tell us what grease they use and how much to me is the key to making this thing work. I have done one with just a light coat and it was better but still rattled.Good point. Interested to see the difference when you do some with the TAPP grease
Use it all. The grease between the splines is the point. If there isn't enough it won't do anything.
I agree. My thoughts on the grease. I think the grease creates a fluid coupler that deadens the sound. Does that make sense?Use it all. The grease between the splines is the point. If there isn't enough it won't do anything.
- 52K
- 55K
