Haha, yes it seems almost every performance enhancement for sleds starts at $500 these days.Ya no kidding! I'm suprised it's not $500!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Black Friday sale...
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Where?Black Friday sale...
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I was joking because the price of it is not $500.Where?
Call a turbo dynamic and see if they have any deals.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Ah ha. I ordered a bunch of stuff on Monday and asked if they were gonna have a Black Friday sale cause I would have waited a few days.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Installed a kit today was an easy install and it does quiet things up. Not sure how long the grease will stay in there but a pretty clever idea.
Turboflash
- Mar 18, 2019
- Southern MN
Why is it called a "knockout" kit?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
it gets the 'knock' noise out?
NIL8GM
- Sep 23, 2019
- Kars, ON
- turbo cat
Yup was skeptical, but installed one last week on a customers sled. Easy install and was surprised how much of a difference it made to an already smooth TAPP clutch setup. Ordered one for my own sled. Cant go wrong for the price.Installed a kit today was an easy install and it does quiet things up. Not sure how long the grease will stay in there but a pretty clever idea.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Never removed stub shaft, just unbolt and pulls out or need slide hammer? Anything particular to make sure the stub shaft is pressed in the bearing well?
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
For easier removal, tap it clockwise so that you have one of the 4 ears where the bolt holes in a spot that you can pry it off. Hope that makes sense?Never removed stub shaft, just unbolt and pulls out or need slide hammer? Anything particular to make sure the stub shaft is pressed in the bearing well?
I have found this works well for removing stub shaft and collar:
-remove belt
-remove primary clutch with puller
-remove stub shaft retention bolts
-place primary clutch loosely on stub shaft
-insert primary clutch bolt back in clutch and thread it in a ways but do not tighten as you want primary clutch to still be loose on stub shaft
-now grab primary clutch with both hands and slide it in and out like a slide hammer the stub shaft and collar should slide right out
-remove clutch bolt and primary clutch from stub shaft
Caution always remember to NEVER turn the engine backwards when doing any work on your sled.
Works for me!
-remove belt
Works for me!
Another idea if it's stubborn is remove the primary spring and use the primary clutch as a slide hammer.Never removed stub shaft, just unbolt and pulls out or need slide hammer? Anything particular to make sure the stub shaft is pressed in the bearing well?
I like that idea of removing the springAnother idea if it's stubborn is remove the primary spring and use the primary clutch as a slide hammer.
ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
I ordered this kit today. But the web site at TD makes reference to some 2017 Sidewinder's use a different shaft that this kit will not work with. Does anybody know how to tell the difference without tearing it down?
- 52K
- 55K
