Fast
- Sep 25, 2018
Nice. Does the hurricane ring take out the 4-5000 rpm rattle or just at idleThey don't compare. Hurricane ring is adding rotational mass which is what is really needed to dampen the clutch harmonics. The ring and grease is IMO a gimmick. I fired my sled up the other day with the TAPP primary and I still have rattle, yes the TAPP still rattles a bit too with a few miles on them, just nothing like the Yamaha primary.
I myself wouldn't bother with the knockout kit again on a machine, it was cheap to try, yes, but IMO its meh, which is fine, I wasn't expecting much for help in the matter. Seems to have helped some of the Yamaha primaries at idle however from some of the videos, but IMO is not "the fix" for a loud primary clutch. Only fix for a loud primary is a quieter primary like the Cats run or a PB80. I ran the PB80 on my old 1200 Doos both NA and turbos, they actually work very well as a trail clutch, you just cant work with engagement RPM at all other than spring changes.
stgdz
- Mar 27, 2021
- Buffalo MN
The grease looks like the stuff I got for my ATV cv axles. Its not a moly grease?I tried to buy the parts from him without his special ceramic grease and he would not sell.
ViperRob
- Oct 16, 2016
- Boone
- 15 Viper
Mine is back to same old clutch rattle after 30 miles. Clutch has all new parts.
RAMSOMAIR
Wish I could put 30 miles on mine lol
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I understand guys. I've tried different Grease and the same result. You did nothing wrong.Wish I could put 30 miles on mine lol
Chalk it off and keep on, keeping on...
FYI. I did a viper and it started to rattle after a small amount of time and when I pulled it a part the ring was stuck on shaft. Once I pulled ring back off, I green loc-tite it and reinstalled the next day. So far so good.
If that ring don’t stay in place the rattle will be back.
Doc Harley
- Oct 17, 2016
- Here & there
Ya know, Mr Sled...I honestly believe 80% will be happy!FYI. I did a viper and it started to rattle after a small amount of time and when I pulled it a part the ring was stuck on shaft. Once I pulled ring back off, I green loc-tite it and reinstalled the next day. So far so good.
I think the load of high rpm being put on the splines is displacing the grease almost immediately.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
How many of you that have had the noise return used green loctite on the sleeve?
It’s a strange deal for sure. Some work and some are questionable.Ya know, Mr Sled...I honestly believe 80% will be happy!
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Well I have installed this kit when it first came out it actually came with blue grease I had to press mine in no lock tight.I just installed my clutch’s from servicing them and holy cow it doesn’t even rattle a bit sounds good but I m sure with due time it will. Need some snow please.
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Pretend its your wife, you won’t hear a thing…
MyOutdoors
- May 4, 2003
- Lempster, NH
- 2020 Sidewinder Ltx Se
out of everything Ive purchased for my winder, this was the biggest waste of life and cash. Would recommend spending your $$$ on burgers and gas!
RAMSOMAIR
It happens
I've been riding this past week.
I went riding without it first. In the bushes my sled had the noise at around 4400.
I have rode a few times since with it in. The noise is barely noticeable now.
Sled idles quieter also.
I loctite them in because the interference fit could be tighter. I use ALL the grease.
I'm convinced it makes a nice improvement and it's a small price to pay.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
All thru the power band. I only hear the turbo now.Nice. Does the hurricane ring take out the 4-5000 rpm rattle or just at idle
- 43K
- 52K
