actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Oops. Damn internet killing my reading comprehension and attention span.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I bought the bushings only. They did not require any polishing/honing to fit properly. They ARE directional as not to push the bushing out of the roller.Ya I talked to him , only 16mm complete rollers. If just the bushing, have to lightly hone bushing after install on your rollers.
04mx
- Oct 20, 2015
- canada
- Yamaha
04mx
- Oct 20, 2015
- canada
- Yamaha
I'm going to be putting the 16mm clutch rollers on and would like to know how they will affect the shift vs stock rollers ?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Less belt pressure in front! They will retard the shift curves or act as "flatter" weight profile
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Where did you buy used rollers? And what price were they? And if you had to buy them new,where to get them and price if you know. ThanksTry a set of 15.5 mm rollers off a viper or nytro. 2500 kms on mine so far and they were used to begin with, still look great. I was pushing out bushings on the stock 14.5mm rollers every 5-800kms before. 270r tune, 85 gram stm weights.
04mx
- Oct 20, 2015
- canada
- Yamaha
Should I add or remove weight to compensate for the bigger roller ?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Add weight for larger dia. primary rollers.
04mx
- Oct 20, 2015
- canada
- Yamaha
The guy told me I would loose rpm ?
KnappAttack
- Feb 19, 2004
- Welch MN
"The guy" was wrong. Try it for yourself, larger primary rollers take away shift force thus requiring more weight to equal the same shift force.
Correct. Right from Yamaha's clutch tuning wall poster - Smaller rollers=increase force. Larger rollers=decrease force."The guy" was wrong. Try it for yourself, larger primary rollers take away shift force thus requiring more weight to equal the same shift force.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Gotta watch the larger rollers, especially with bigger power. Belt slippage may become a big issue down low then.
Dan
Dan
04mx
- Oct 20, 2015
- canada
- Yamaha
Anyone familiar with the 4 hole magnetic clutch weights ? I have a set of ssi arms I could use to add more weight then the stock arms
Mototown
- Sep 11, 2018
- Apex 40 th
Still have that wall poster ..lolCorrect. Right from Yamaha's clutch tuning wall poster - Smaller rollers=increase force. Larger rollers=decrease force.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
That's my bad, I posted that wrong....."The guy" was wrong. Try it for yourself, larger primary rollers take away shift force thus requiring more weight to equal the same shift force.
- 46K
