olivia317
Finally got to test and tune my Nytro after installing MPI's Stage 1 supercharger kit. Quickly discovered my factory pump will not keep up so I need to upgrade the pump. I have a trip planned next week to Michigan and won't be able to get the upgrade done in time. My question is, can I put the 180 kit pulleys back on, lower the boost to 5-6 psi, and not remove anything else. Will I create any drivability issues? Don't want to remove the intercooler if I don't have to.
That would work. Might be a little heavy on the clutching if you updated that but for trail riding it wont hurt anything. You will also have to readjust fuel to meet the new boost number when you put it back to low boost.
pro-man
What pulleys are you running now? What is the boost pressure?
