Freak
Please state your boost, Altitude and your main jet THNX!
20lbs - 8-10k' - 135m (too lean)
12lbs 500-800 feet Stock main that is 135 i think?
snowy1
18lbs-10,000 ft.- 136.3 mains needs alittle more.cpr kit with bigger turbo added.
monker
how about state the kit you are running too...
8lbs...0-2000ft...132.5 (probable 130 soon)...MPI supercharger
rerod
Michigan 1000ft, 9-16psi 140 jets.
Colorado Yamaha
- Sep 4, 2005
- Colorado Springs
- 2010 Nytro MTX - MCX
rx-hi
MC-X rear 3-6000 130 main
KbxSrx
MPI 5-10 lbs 2500-9000 feet 130
MCX-rear, 10-18 lbs, sealevel , 135 mains.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
MCX REAR, 11-18 lbs, 0-3000 ft, 140 mains
Lets add carb springs too. I run Holtzman green carb springs with needles in 3rd position. Pilots 17.5, screws 2 turns out.
Blue shadow
cpr front mount at 13 psi with 130 mains so far sealevel
Otis RX
Bender... 1,400 ft...... 13psi.......135 main.......stock springs.......will start messing with Holtzman spring inventory.
sledheadgeorge
8 to 16 lb boost, stock mains, went down one size in the pilots, stock carb springs, 800-1800'
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
MPI Stage 1 SC kit 10 lbs? boost(high boost pulley configuration) at 7000-10,000+ elevations 127.5 mains, 25 pilots screw at 2 3/4 turns out needles stock. Slightly lean at idle (13s on the O2) lean side of range in the mid (mid- high 12's on the O2) and running right on at WFO (11s to low 12s on the O2).
Jim
Jim
