Warp
Does anyone have any Picture of the install of the marginal snow kit?On my 2006 Attak on the rear there is three bolts on the rail ,can I remove one of them and put the wheel there rather than having to drill my rail? Thanks
fireman1069
I checked into it and found it was easier to just order the kit yamaha made for the '06-'07 attak. I don't have a picture but this is where I bought mine from and it was the cheapest. $66 shipped. It uses two of the bolt holes in the center of the rail to be mounted on the outside. I'm not sure of the clearances if you mounted it on the inside but it might work. It uses the 3-3/8" (?) size wheels. It also looks to be somewhat adjustable to move it forward or backward if needed. Hope this helps. If you are also looking to put a kit up front, wahl bros makes a simple one that mounts on the inside at the bend in between the rails for $43. You may have to shorten the width (grind off each end) of it about an 1/8" to get it to fit inside but it works great and it's pretty reasonably priced. After mounting these my track is much more friction free. Good luck.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... K:MEWNX:IT
Warp
Thanks for all your help,I had the wronge kit for my Attak, but I got a call from the dealer that the new kit was in.fireman1069 said:I checked into it and found it was easier to just order the kit yamaha made for the '06-'07 attak. I don't have a picture but this is where I bought mine from and it was the cheapest. $66 shipped. It uses two of the bolt holes in the center of the rail to be mounted on the outside. I'm not sure of the clearances if you mounted it on the inside but it might work. It uses the 3-3/8" (?) size wheels. It also looks to be somewhat adjustable to move it forward or backward if needed. Hope this helps. If you are also looking to put a kit up front, wahl bros makes a simple one that mounts on the inside at the bend in between the rails for $43. You may have to shorten the width (grind off each end) of it about an 1/8" to get it to fit inside but it works great and it's pretty reasonably priced. After mounting these my track is much more friction free. Good luck.
Tycho998
Could you post a picture and the Pt# once you have it installed. I've gone to two different dealers and neither kit worked. My 06 has rail stiffeners bolted on where the kit should go.
Warp
What you do is get the kit with the long brackets in it and you take out two of the front bolts in your rail stiffener and fasten the wheel with longer bolts included in the kit.I will try to post the pics. tomorrow.But in the mean time here is a link to see the one you need.The part # SMA-8FA95-00-00 fit on the curve and part #SMA-8FT95-00-00 fits the rear. http://www.ty4stroke.com/viewtopic.php? ... +wheel+kitTycho998 said:Could you post a picture and the Pt# once you have it installed. I've gone to two different dealers and neither kit worked. My 06 has rail stiffeners bolted on where the kit should go.
camoman
If I was running 135mm Doo wheels would I use 135mm Doo wheels instead of the ones that come in the pack?
auto385
2007warrenp said:What you do is get the kit with the long brackets in it and you take out two of the front bolts in your rail stiffener and fasten the wheel with longer bolts included in the kit.I will try to post the pics. tomorrow.But in the mean time here is a link to see the one you need.The part # SMA-8FA95-00-00 fit on the curve and part #SMA-8FT95-00-00 fits the rear. http://www.ty4stroke.com/viewtopic.php? ... +wheel+kitTycho998 said:Could you post a picture and the Pt# once you have it installed. I've gone to two different dealers and neither kit worked. My 06 has rail stiffeners bolted on where the kit should go.
I just checked with the Yamy dealer and he said the first part #was for an Apex and the second for an Attak, both to be installed in the front position at the curve. Any info on this because I want to install some in the front and the middle of my 07 Attak GT.
The SMA-8FT95-00-00 is the rear for the 06-07 Attak. It comes with the mounts for the rails.
Click on the link above to see the pic.
Not sure if the rail kit at the curve are different for the Apex and Attak.
bottlerocket
Yamaha does not offer wheels for the front of the rails that I know of. Jerry from Fix powersports sells a kit that you have to drill holes in the rails (that voids the factory warrenty) with 3 wheels at the curve.
darv
- Aug 9, 2005
- 08 Apex 40th LTX
yes yamaha sells a wheel kit for the front of the rails
camoman
camoman said:If I was running 135mm Doo wheels would I use 135mm Doo wheels instead of the ones that come in the pack?
Never mind I bought the marginal Snow kit last night and realized it has small boggies.
If I am running the 135mm doo wheels will the marginal snow kit still come into play and help with slider ware?
darv
- Aug 9, 2005
- 08 Apex 40th LTX
yes you can and it will help I do it to all my sleds
camoman
Thanks! I actually wore right through my sliders a couple nights ago.. Never did that before and it was right in the area that the marginal kit installs at.
shawnj
As I mentioned in a previous post on this topic the kit with the straps did not work for my 2010 ltx gt. I was able to mout the kit without the straps up front, I've ordered another of the same for the back as it'll line up and all I have to do to mount it on the back is enlarge one hole very slightly. Even if the kit with the straps had of lined up on my sled, with it together the bottom of the wheel would have been sitting a bit too high to even make contact with the track, I'd say close to a 1/4" away.
