MUSKOKA SIDEWINDER LTX LE
- Dec 8, 2006
- Huntsville, Ontario ,Canada
We also are having the same situation and motor is on the way.
1CoolZ71
- Mar 14, 2017
- SE Wisconsin
- 2017 T-Cat
The one we had was a 2017.
If the OP has a 2019 with the same issue, that's scary.
Who knows how many could be out there with defects.
If I had my motor blow, I would magnaflux the head and check for porosity.
- Dec 8, 2006
Head gasket was changed and after 20 kms coolant bottle empty and back into the oil.
RIKMAN
- Feb 21, 2008
- Val d'Or, Qc
- 2020 Srx
Thanks guys, guess we will see after a few rides.
Rik
Rik
RIKMAN
- Feb 21, 2008
- Val d'Or, Qc
- 2020 Srx
Did you find the issue?
Finally, coolant is mixing in oil.
Grrrr...
- Dec 8, 2006
Cracked block ughhhhh
- Dec 8, 2006
They did a head gasket and then within 20 kms antifreeze was back into oil so motor is being replaced
RIKMAN
- Feb 21, 2008
- Val d'Or, Qc
- 2020 Srx
Was it stock or tuned? Mine seems to leak in oil at 16lbs of boost. How much boost can oem head studs withstand??
- Dec 8, 2006
Heres the thing I have a 2017 and ran over 30 LBS of boost for 2 seasons 0 issues I also have my 19 SRX also running the 30 LBS Mark and 0 issues
JLR
- Dec 6, 2006
- Winnipeg, Mb
- Currently, 2017 Arctic cat thundercat 2018 sidewinder xtx se 137 precision stage 4, 2025 Yamaha Srx bone stock
Wow that on stock motor, or headstands done?
- Dec 8, 2006
Stock motor on both my 17 and 19
JLR
- Dec 6, 2006
- Winnipeg, Mb
Thats good to hear motors are built well.
1CoolZ71
- Mar 14, 2017
- SE Wisconsin
- 2017 T-Cat
I doubt boost pressure would affect this issue. The coolant is leaking through the casting into the oil or into the cylinder.
Higher boost may keep the coolant OUT of the cylinder because of the higher psi.
The higher boost is in the cylinder and does not affect the coolant pressure or the oil pressure
RIKMAN
- Feb 21, 2008
- Val d'Or, Qc
- 2020 Srx
FYI.
Head gasket was the culprit. Pushing coolant under high boost from #3 cyl towards the timing chain compartment.
New head gasket and ARP studs going in.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
How much boost?FYI.
Dan
- 14K
