MPH / Odomètre problème ?
MattB_Qc
Quebec
Canada
Polaris Rmk Assault 2018 - Sold
Spring Order Sidewinder LTX-LE - 2021
hey, guys I just notice my Odometer and MPH are not showing numbers ... stock at 0 .. I see rpm I see engine hours temps everything but those 2 any idea? brand new 2021 ltx LE
Lower right push button scrolls thru for hour meter, trip meter, odometer.
Top left button scrolls thru for mph or rpm.
Its in your owners manual on how to work the gauge.
If that doesn't work take it to dealer for warranty work.
I know how to work the gauge mate lol MPG AND ODO are stuck at 0 ! and dealers are not open now because of covid #*$&@ ... :(
Ok. Gauge pulls straight out by hand. Check and see if electrical plug is connected all the way.
Also speed sensor on chaincase and plugs into harness near oil tank sight tube.
Check and make sure hood harness is connected all the way above coolant tank. One other place to check is ECU connector .
Good luck.
will do tomorow thanks
Make sure the pickup sensor had been attached to the chaincase cover.
I know it's new, but quality control on these things.....
I guess ill need to remove the exhaust to check this out?
No, right beside your right foot
also check the gauge and accessory port fuse fuse. I had my accessory port blow a fuse and it did the same thing....
Black rubber like strip
Thanks a lot found the problem... when I bought the sled I asked at the same time to change my track to ripsaw2 1.5 .. and the guy did not plug back the wire right where you told me to check! thanks, lots !!! and guys from QUEBEC BE AWARE STAY AWAY FROM SM SPORT DEALER
Great problem solving !
Avoided a trip to the dealer .
Why start anywhere else but on TY !
Quick knowledgeable responses !
