SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Will the dragy unit hold up to the elements? Trail ride mostly but the info it provides and price are cool.Is what suitable ?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Been running mine all winter with no issues in the cold. It's been flopped around to half a dozen sleds. All your buddies need to do is download the app then they can use your dragy.Will the dragy unit hold up to the elements? Trail ride mostly but the info it provides and price are cool.
- Apr 14, 2003
- Hessel, Michigan
Here is a quick vid of my winder as promised.
As noted, only mods to this sled from stock are:
Hurricane tunes 240/270/300
EVO Charge Tubes
EVO Blow Off Valve
EVO exhaust
Thunder Products Clutching
Aftermarket cold air intake
EVO Charge Tubes
EVO Blow Off Valve
EVO exhaust
Fast
- Sep 25, 2018
Did you take .070 thou off the helix to match the primary? Plus .070 thou off the split collar in the primary,How high does the belt run in the primary?Yes, I took out .035" each side of my primary and trimmed down the hub on my secondary. The belt was polishing the center...LOL
Fleecer
- Jun 13, 2014
- 2019 SRX
No studs is correct![]()
After watching the video, I noted that sled has one stud......the driver!!
Congrats....those are very impressive numbers.
- Apr 14, 2003
- Hessel, Michigan
Yes, machined .070 in the primary and machined a lot off of the helix. I found the helix was what was really holding me back from top mph.
The primary clutch sheaves wiped all the marks off of them...they are polished right to the top. I will put my CameraFi 6mm camera in the clutch area in the next 2 weeks as the sled is switching over to asphalt
Thanks bud!
DMCTurbo
- Nov 12, 2005
Very nice Terry! Where did you get the snowflap?
Kenzie
- Feb 27, 2015
- Viper ltx se 137 turbo
For stock clutches this sled is moving out with 21/41 gears. Some great clutch massaging going on. Be a few sets of clutches sent to thunder products after this post I bet.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Mine would go for 911 cover and balance without this post!
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Send those clutches in everyone!
- Apr 14, 2003
- Hessel, Michigan
Got it from a great friend on here.... He had major issues with his turbo Viper clutching and was so unhappy with it. I found out what the problems were and got them fixed. When I saw him the next time, he brought me that snow flap and thanked him big time! I love the snow flap and even being long, the straps that hold it out keep it from being sucked under in reverse.
- Apr 14, 2003
- Hessel, Michigan
Thanks bud!
Friday night the SW was switched from trail to asphalt in a matter of 5 hours, start to finish.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Using stock suspension?Thanks bud!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Are you running a header for asphalt?Thanks bud!
stone88
You need anew antennaeHow long does it take the draggy to link up? My TD GPS is taking half hour sometimes more the last few times I've tried to use it.
- 7K
