attak_rider
- Nov 28, 2014
- Ann Arbor, MI
- 2006 yamaha Apex ulmers clutch kit, air box mod, power commander, reinforced rear susp. pioneer performance tuned shocks
2015 yamaha sr Viper Ltx se, Hurricane 190 turbo kit, ulmers clutching, osp adjuster with 8dn, axys rear and center shock, slp mohawk skis
My mpi kit from Yamaha is currently on back order, but when it comes in I will definitely be ready to put it on immediately. Does the kit come with a pretty good set of installation instructions, and is there anything I will need to get that the kit itself does not come with?
Studroes144
- Oct 30, 2013
Just start working the arm muscles cuz you'll need them!
Yes they are good now... leave yourself an entire weekend to get it installed if you have never done one before.
matt@mpi
- Feb 10, 2011
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Matt, whats all the talk about Yamaha testing new clutch setup now with MPI ? Do we need them reworked? I could care less about top end speed so will the stock clutch work? When we spoke a few months ago you stated nothing needs to be done, maybe something has changed?
matt@mpi
- Feb 10, 2011
Yamaha wants a clutch spec that's cost effective using as much of the stock parts as possible. That's what their working on. The stock weight could be used with some 7 gram brass rivets that we make but its a stretch. To get them most out of the turbo new weights, springs, and helix are in order. What Yamaha wants from a weight profile of a N/A doesn't always work for boost.Matt, whats all the talk about Yamaha testing new clutch setup now with MPI ? Do we need them reworked? I could care less about top end speed so will the stock clutch work? When we spoke a few months ago you stated nothing needs to be done, maybe something has changed?
yamahaguy
Ride SAFE
- Apr 20, 2014
ok, thanks Matt
Studroes144
- Oct 30, 2013
Just out of curiousity, on your boosted vipers are yous still running yamaha belts or are you going with aftermarkets?
Diamond Driver
I am still waiting for my kit also. i tried to open Matt's link to install instructions but said invalid url?
Sent from my iPad using Tapatalk
yamahaguy
Ride SAFE
- Apr 20, 2014
The link worked for me, I have downloaded it and reviewed it. Its a big .pdf file so if your looking at it on a phone, might not work?? Try it from a computer, its also on MPI's new web site.
Very good directions that MPI has put together, you can tell they spent some time on it. Lots of steps but over all looks like it will be a very easy install. I'm looking forward to installing them both when the kits arrives. We got snow here and are riding in the mean time... hurry Matt..
Thats a PDF download... its not going open and download on a phone.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Just read the pdf. (It worked on my phone) looks like some good instructions! Does the GEMS controller come preset up? Or does that require setup by the user? If so, that part of the instructions are pretty vague/not there..
Studroes144
- Oct 30, 2013
Without an afr gauge you can't adjust anything since you won't know which way to go, once u have an afr gauge it's pretty straight forward adjusting the gems
matt@mpi
- Feb 10, 2011
The GEMS is pre-set.Just read the pdf. (It worked on my phone) looks like some good instructions! Does the GEMS controller come preset up? Or does that require setup by the user? If so, that part of the instructions are pretty vague/not there..
tapex_07
- Feb 15, 2009
Right I get that you need a AFR gauge to make adjustments. That's why I asked if it came pre loaded.
