My sled CAN NOT break 109mph on GPS!!! Help!!!
What conditions are you running on when you GPS at 109mph?
How much do you weigh?
What RPMs are you running when you are going 109mph??
Running on the trail.. i would think 109 would be a very good speed.. On ice.. it would be about 4-7mph low!
What rpm are you running ?
109 is not real bad, I would think that is about 120-122 on the speedo.
On my 05 with CPR air and clutching in good conditions I will hit 121-125 by the speedo. One time this year in very good conditions I got 130 by the speedo. I think that would be about 117 on a gps. I would think a 06 could do better.
Remember conditions make a big difference.
Loose snow can pull them down a lot...
I was reving 10,600ish on the lake some bare ice with an inch or two of snow, in deep snow revs 400rpm lower. Distance was about a mile or so. Suited up I'm 185 lbs. The dream meter was at 194kmh.
I have hit 111 mph. 128 gps (once). Still only 200 miles on it. 10,500 rpm. Hit 109 and 110 several times. I've been doing many things over the last two weeks to try and find a little more speed but in general that's what they all seem to be running. The clutch kit was so worth it. I can kill my buddys Mach Z everytime 0-80. Our top speeds are usally exactly the same. The last time it was 110. He's back to the Doo dealer today trying to find out why I beat him every time. :-o
