kinger
Ok guys I have a 25T tooth top gear and I 'believe' a stock lower gear. The sled as nitrous and the 25T was added for a little more top end. reading around it looks like a large top gear compared to stock apexs (what is stock for rx1 21T?)
Playing with the interactive gear calculator what is the lower gear stock?
Thanks a lot!
Thanks a lot!
rx1racer
24 -38 is stock gearing.Most will tell you they get better performance and more top end with the 23 as top gear.
05 rx-1 candy red ,ecp kit,cams ,ported heads,qc-1 pipes,172.5 mains.wiseco hi-comp pistons,hauck clutching,timing advance,and a dose of high octane fuel for good measure.
Go with a 23 top gear or better yet a 40 bottom gear. Less binding with the 40
woodchk454
Ive got 23-40 (or was it 22-40) cant remeber for sure now i better check. I had to buy a new chain to run the gearing I got, and i love everythingabout it but the gas mileage.
culvert
I have two 40 tooth bottom gears for sale if needed.
Pm for prices
Pm for prices
- 14K
- 8K
