ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
The gear probably wasn’t clean and had a large piece of something sticking to it from the gear lube. When the sprockets started turning the piece got wedged between the gear and chain causing damage to the link. Gear lube is very sticky. If it was set on a dirty floor could have been anything. Or it could have had a piece in the chain.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Your bushing is worn out in the upper gear.Put another washer behind the top gear(inside), then you will need a washer half as thick for the outside. This will keep them engaged better.
No it's not, I did this on my 18 when it only had 100 miles on. Bushing perfect. The gears do not fully engage.Your bushing is worn out in the upper gear.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Ok well it’s usually the bushing
mcuhan
- Jan 3, 2015
- Iron Range MN
- 2018 Sidewinder RTX-SE
2008 Apex GT LTX
2004 Viper
2000 SRX
2000 Mountain Max 700
1980 Enticer
1981 Exciter
1986 Excel III
Found a spare on the shelf at dealer an hour away. They ordered it for a service job but never needed it. Called two in MSP and Port and all reported backorder. Paid a kid $50 to jump in my truck and go get it. Whew!!Get a chain from Cat, Wahl Brothers or speedworks. Season is to short
- 19K
- 6K
