14ftn
07' Apex GT (8050 miles) I had an erroe code 12. Found out that I should replace the stator and attached sensor.
I purchased an aftermarket stator from RM STATOR. Great pricing, delivered the next day. However, I have it all back together.
The erroe code is gone, but when the engine roles over it will not start. I do get some real loud back fires. Something is not right.
I'm wondering if there is a timming issue with the rotational position of the stator? Does anyone have any input?
jackback
What was gone the stator or the crank sensor, if the code is gone its likely flooded. I have read that RM stators mounting holes are to large and you have to move the pickup close as possible to the fly wheel to get it to work. Just replaced mine last week with a original used one $100.00 bucks plug and play, took about two hours to replace one hour of that was removing the old gasket!
14ftn
Just debating on stripping it back down to try to move the sensor closer. However the code 12 is the sensor and does not display an issue. However the OHM test reads 1.2 and the spec says it should 0.6??? I have a call into RM to see if they have any technical direction or input. Thanks
turbine tester
- Apr 8, 2011
- PEI Canada
- 2006 Attak
Have a read through this, This was my experience with a non-yamaha stator
http://www.ty4stroke.com/viewtopic.php? ... ht=#986275
apex55
Sensor needs to be within.010"
Mine went this weekend also. The reviews from RM Stator are not all that good. Parts are from China it seems. $129 is a good price though. Can get an OEM for $234 out of Partzilla.
cat hunter
We replaced 2 faulty RM stators this winter with OEM .Pay the extra !!!
14ftn
Thanks for the heads up! I have removed the RM Stator. Hopefully the new OEM arrives today and I can put it back together. Did you have any issues dealing with RM to return the faulty units?
Warp
- Apr 12, 2007
- Corner Brook
- 2006 Attak
Did the OEM stator work out for you?Thanks for the heads up! I have removed the RM Stator. Hopefully the new OEM arrives today and I can put it back together. Did you have any issues dealing with RM to return the faulty units?
Try flipping the two wires at pickup plug.
Warp
- Apr 12, 2007
- Corner Brook
- 2006 Attak
I bought the whole assembly not just the crank sensorTry flipping the two wires at pickup plug.
Doesn't matter. Try switching those two wires as I already suggested.I bought the whole assembly not just the crank sensor
When it comes to aftermarket RM would be my last choice.
Warp
- Apr 12, 2007
- Corner Brook
- 2006 Attak
I will just return and buy OEMDoesn't matter. Try switching those two wires as I already suggested.
- 21K
