It’s not lean till it’s being run on the limiter I will bet. It’s very hard to keep it off the limiter. Even a small downhill and it’s there. Have no idea where peak up is since no specs out there. I am going to clutch it to 7600rpm. Tonight.What is peak HP RPM? I would clutch it so that it still is able to climb slightly above the peak HP RPM. Lugging it/clutching it to heavy, can have bad results if A/F is on the lean side.
YamahaMike
Hi guys new here got the same problem with my SX Venom this pass Saturday the wife was driving it for the first time @ maybe 20-25km/h code P1324 and the motor just died it turns over but will not startany body else have a transporter/ venom cut out when run hard. Got a couple codes p1324 that the dealer tells me is fuel related. running the same fuel in my sidewinders one tuned so I’m having a hard time believing it’s poor fuel. Exhaust temp readings on gauge runs almost full which is around or above 1100* Just wondering if they sent these thing out with a lean program. Driving at 35mph at less than 1/2 throttle and exhaust temp is topped out.
Something is wrong
Any ideas anyone
I put 13g wieghts in mine and it helped but still hitting rev limiter. Just put 14g in. Will test tomorrow.
Check compression. Should be 120psi with throttle wide open. Maybe fouled a plug or stuck injector closed. Little Isopropyl and if needed tap the injector lightly with screwdriver handle might free injector up.Hi guys new here got the same problem with my SX Venom this pass Saturday the wife was driving it for the first time @ maybe 20-25km/h code P1324 and the motor just died it turns over but will not start
Hey guys. Having the same issue with my transporter. I also have a venom. No code on the venum but it does cut out a bit. I just got back from dealer and they had no clue. They changed the spark plug and cleared the code and said it was fixed.
But as soon as i tested it same code came back on the transporter.
RAMSOMAIR
Yep, that should fix her up!!
Seeing as i have two of these sleds and one is working fine im going to see if there is any difference in The injectors. Any thing else i should look at? I feel like i should swap the ecu but don't want to void warranty.
MattM
- Jan 30, 2021
- 2021 Transporter Lite
I am also having the same issue with the Transporter Lite throwing the P1324 code
It cut out and would not start for me then started a hour later. does this mean I have done some engine damage? should I pull the exhaust manifold and check the piston?
I am in contact with my dealer and have put a call into Yamaha Canada
Thanks everyone for all the info in this thread!
Sydnee
- Jan 30, 2021
- Sault Ste. Marie
- Yamaha Transporter Lite
My Transporter is cutting out at high RPMs as well. Ive seen the 1324 code a few times now. When I see the code I shut the sled off, start again and its totally fine. It doesnt always cut out on me. Not sure whats causing this.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Mine has been at dealer for two weeks for engine replacement. Will surely update on what changes are made to address the issues.
I sent this thread to my dealer and asked them to contact Yami for repair bulletin. They got back to me and said that they think it is clutching I have since run 1/2 Ave gas 1/2 premium and it ran great with no code and really fast. Rpms are reaching up to 8150.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Talked to dealer yesterday and Yamaha is trying to find parts to fix my engine.
Should be 7600rpm. Clutching is off. Riding on rev limiter can do all sorts of bad things.I sent this thread to my dealer and asked them to contact Yami for repair bulletin. They got back to me and said that they think it is clutching I have since run 1/2 Ave gas 1/2 premium and it ran great with no code and really fast. Rpms are reaching up to 8150.
YamahaMike
Just got the news from dealer it’s blown up needs new engine 65psi compressionCheck compression. Should be 120psi with throttle wide open. Maybe fouled a plug or stuck injector closed. Little Isopropyl and if needed tap the injector lightly with screwdriver handle might free injector up.
YamahaMike
A total of 400 SX Venom blown up in Canada not looking good
- 8K
