mike800
- Jan 20, 2022
- Anoka County, Minnesota
- 137" Procross
There's an easier way for skid removal and no reason to take out the front crossshaft or loosen the track, springs etc., especially if you have a helper. Put the sled on it's side and remove a rear bolt. Switch sides and remove the remaining bolt, balloon the track slightly forward and lift the skid out. On installation we take the small leg of the springs off the blocks to collapse the rear arm and install the rear bolts, reattach the small leg of the springs. A hyfax change is a 30 minute job with an experienced helper.
This Hygear is a fair depiction of the process we have used for thirty years although it has the mountain type skid with front bolts vs. a crossbar.
Watch Videos
Find Product Installation Videos on your performance products! Spring Kits • Dual Pressure • Slicast • 141 Pro Linkage • Heavy Duty Axle Kits
www.hygearsuspension.com
The spring tool for the short legs can be purchased or you can weld one up pretty easy,
Arctic Cat Rear Suspension Torsion Spring Tool
Arctic Cat Rear Suspension Torsion Spring Hook Setting Tool - 0144-311
www.countrycat.com
Could your take the time and make a video with the cross bar?There's an easier way for skid removal and no reason to take out the front crossshaft or loosen the track, springs etc., especially if you have a helper. Put the sled on it's side and remove a rear bolt. Switch sides and remove the remaining bolt, balloon the track slightly forward and lift the skid out. On installation we take the small leg of the springs off the blocks to collapse the rear arm and install the rear bolts, reattach the small leg of the springs. A hyfax change is a 30 minute job with an experienced helper.
Watch Videos
Find Product Installation Videos on your performance products! Spring Kits • Dual Pressure • Slicast • 141 Pro Linkage • Heavy Duty Axle Kitswww.hygearsuspension.com
Arctic Cat Rear Suspension Torsion Spring Hook Setting Tool - 0144-311www.countrycat.com
I’m trying to understand how you balloon track and just lift it out? When do you unhook the front?
What video form Hygear are you specifically referencing?
Also on that tool how does that work on the rear springs?
For me I usually never have a helper and this is what works for me, but I am really interested to see it done.
mike800
- Jan 20, 2022
- 137" Procross
We never unhook the front on a Procross chassis with the slide-action skid. With the skid turned out from the tunnel the front arm slides rearward enough and off the bar. If it is a struggle go ahead and remove the short arms of the springs to collapse the rear arm for removal. The slot on the bar grabs the short arm; twist with the handles and lift off the adjuster blocks.Could your take the time and make a video with the cross bar?
The video referenced is for the 141 Pro LInkage kit install.
earthling
Got it. Thanks I can’t believe I have not seen that video before. For just skid maintenance that looks easier.We never unhook the front on a Procross chassis with the slide-action skid. With the skid turned out from the tunnel the front arm slides rearward enough and off the bar. If it is a struggle go ahead and remove the short arms of the springs to collapse the rear arm for removal. The slot on the bar grabs the short arm; twist with the handles and lift off the adjuster blocks.
mike800
- Jan 20, 2022
- 137" Procross
I bought my tool in the nineties; the price is silly now. I bet a person could weld/make one now for $10 and a Mich Lite.Got it. Thanks I can’t believe I have not seen that video before. For just skid maintenance that looks easier.
mike800
- Jan 20, 2022
- 137" Procross
I PM'd you back. Good luck with the wrenching and have a good day.I bought my tool in the nineties; the price is silly now. I bet a person could weld/make one now for $10 and a Mich Lite.
Right!! No one has the darn things either.I bought my tool in the nineties; the price is silly now. I bet a person could weld/make one now for $10 and a Mich Lite.
mike800
- Jan 20, 2022
- 137" Procross
I should add that I use a handlebar stand in addition to a rubber tire chock to keep these Procross chassis from tipping too far to the side. I don't recall where I bought it but this is the same thing.Right!! No one has the darn things either.
Steering Post Stand
SPSTD1: Steering Post Stand takes the back work out of many maintenance jobs by preventing damage (windshield, levers, mirrors, etc) when the sled is tipped on its side. Stand slides into the tubewelded tothe top of the steering post which supports the handlebar riser. The shaft is .63" (16mm)in...
fettbros.com
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Good video. With that said, I have not been a fan of laying a 4 stroke on its side to pull the track.
earthling
I think it works the same way if you just raise the rear a ton. Its the angle of the track to the sled that makes it easier. I do it the way @MrSled does it but I looked that video up right away to see if I was missing something.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
You are correct. Raising the rear is how I do it. His work lift is the key. I am getting too old to work on the concrete floor. LOLI think it works the same way if you just raise the rear a ton. Its the angle of the track to the sled that makes it easier. I do it the way @MrSled does it but I looked that video up right away to see if I was missing something.
I just cut the safety loops tops off for springs. Then no need for a tool to remove short end. Raise rear up enough and skid falls out with two bolts at rear removed.
I finally got my hands on a Arctic Cat Rear Suspension Torsion Spring Tool, how the hell does that work? LOL Can someone explain it or send me a video?We never unhook the front on a Procross chassis with the slide-action skid. With the skid turned out from the tunnel the front arm slides rearward enough and off the bar. If it is a struggle go ahead and remove the short arms of the springs to collapse the rear arm for removal. The slot on the bar grabs the short arm; twist with the handles and lift off the adjuster blocks.
- 48K
- 35K
