Chris Hammer
- Dec 26, 2020
- Sydenham
- Rx Warrior 1000 cc LE 2004
Hey guys, got a 04 Rx Warrior. Just replaced the stator and pick-up on my sled. Before that I had the sled running in the winter but was blowing the main 10 amp ing fuse. Now, after putting it all together, I have 0 spark? I tried all 4 ignition coils and checked plugs. I also just replaced the starter solenoid right from the dealership.
There are 2 30 amp green fuses, I have 12 volts on the "+" side but nothing on the "-" side....not sure if there should be or not? (on the starter solenoid)
I think this has to be a simple fix. I checked the resistance on the stop button switch and 2 of the 4 wires are good, 0.00 ohms, on the other 2, moving the switch up and down gives me nothing.
Any help would be great. I have put a lot of money into this since it got hot earlier this winter.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Did you use an OEM stator and pick up, or aftermarket? Have heard of quality issues with the aftermarket part.Hey guys, got a 04 Rx Warrior. Just replaced the stator and pick-up on my sled. Before that I had the sled running in the winter but was blowing the main 10 amp ing fuse. Now, after putting it all together, I have 0 spark? I tried all 4 ignition coils and checked plugs. I also just replaced the starter solenoid right from the dealership.
Chris Hammer
- Dec 26, 2020
- Sydenham
Hi 03RX1-ER-LE, it was from Kimpex which is made in Quebec Canada, it was $ 180 CND, probably made in China like the rest of them!
As far as I know, there were no problems with this stator though I will contact the person I got it from. Still seems weird, I drove it into my shop when we had snow, now nothing...Do you think the new stator or pick-up is a dud? There is only one way it can go into the casing when I put it in.
Brotherdan
- Sep 8, 2017
- Belmont,maine
Did you check stator& pickup coil output with multimeter?did you use oem or aftermarket parts?Hey guys, got a 04 Rx Warrior. Just replaced the stator and pick-up on my sled. Before that I had the sled running in the winter but was blowing the main 10 amp ing fuse. Now, after putting it all together, I have 0 spark? I tried all 4 ignition coils and checked plugs. I also just replaced the starter solenoid right from the dealership.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
The trigger is used for spark. When I had a no spark concern on my 03 RX1 all I replaced was the trigger with a Yamaha one and it fixed my no spark concern.
Others on here have had issues with aftermarket IGN parts for what it is worth.
the trigger coil wires are known to come backwards in aftermarket stators vs oe. most guys just re pin the plug and it is gtg.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Forgot about that, having another senior momentthe trigger coil wires are known to come backwards in aftermarket stators vs oe. most guys just re pin the plug and it is gtg.
Chris Hammer
- Dec 26, 2020
- Sydenham
Hi, I used a aftermarket part, new.Did you use an OEM stator and pick up, or aftermarket? Have heard of quality issues with the aftermarket part.
Chris Hammer
- Dec 26, 2020
- Sydenham
What do you mean by trigger? The pick up you mean?
Chris Hammer
- Dec 26, 2020
- Sydenham
Thanks, so just reverse the 2 wires for the pick-up aka trigger coil? Trying to see what you guys mean about trigger!
Chris Hammer
- Dec 26, 2020
- Sydenham
Hi, yes set ohms at the lowest value (20) and pick up coil was at around 220 ohms, the stator it's self was reading at "0" across all three wires.Did you check stator& pickup coil output with multimeter?did you use oem or aftermarket parts?
yes.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Same thingThanks, so just reverse the 2 wires for the pick-up aka trigger coil? Trying to see what you guys mean about trigger!
