Big-zig
- Jan 30, 2004
jtssrx
Post a pic
JDKRXW
This will work on non-turbos too....... right???
Big-zig
- Jan 30, 2004
Sorry Guys, Out of town all Thanksgiving weekend. I'll post pics tonight. Yes, it will work for non-turbos as well.
LazyBastard
Any improvement in case venting with it, or is is strictly a separator?
Big-zig
- Jan 30, 2004
This is more for separation and mess control than increasing breathing, that said, it would enable unrestricted venting of the case. I will post pictures as soon as I can.
JDKRXW
How does it mount...... flat, on its side???..... any ideas about where to run the return on a stock sled?
Big-zig
- Jan 30, 2004
you should mount it so the return line comes out the bottom of the separator. You can run the return line back into the motor or into the oil res. The unit uses gravity to return the oil so you would want it mounted higher than the return destination.
jtssrx
Can you make a bigger Return Nipple?
Big-zig
- Jan 30, 2004
The separator has a filter inside that catches splattering oil and that oil then collects at the bottom of can and gravity feeds back to motor. I don't think a larger return line will be necessary because not a large quantity of oil will collect at any one time. This unit is very light weight (only a few ounces).
Big-zig
- Jan 30, 2004
The oil return fitting is approx 3/8" id. It is not small.
jtssrx
If you mount that between the Steering posts you could drain in the valve cover. If you went to a larger ID on the return would it hurt it???
- 36K
