TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
No!
I will leave it then. No ice buildup there?
As far as I know there is no white available for anything other than 1100. At least last year when I bought it.
Thanks guys
Thanks guys
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
No ice or snow buildup.
1100T Sno Pro black and white, 2014
Did you guys with skids cut this area out to restore hole?
Yes. I didn't see the point of leaving them blocked off. I took a hole saw to each side after the fact and put a hole in each side. Whether I drag the snow in the foot area or any other way, I like the holes there.
That sounds like a perfect compromise. Should be plent of strength left like that. Thanks Drumz!
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Well I am glad that you got it to work Cannondale. One thing I did was add a.cpl nylon washers between the skid plate protector and the actual access cover so the protector cover plate sits flesh with the rest of skid plate protector. Yes we all learn from other ppls ideas to make life easier. Gotta love TY!
For sure! Maybe now I will go off trail again.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
Large holes on the bottom make me nervous, think I'll keep mine closed. Don't like the large objects that can come through them.
True a stick or something wose could hurt a guy but so could slipping out because of ice. Maybe a bunch of smaller holes?
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
There is so much hot air that comes out of there you could not make ice in that footwell if it was -30 F. Before you cut, check out how much hot air comes out of the footwells! My uninsulated boots stay very warm and never get wet when riding. I spent a lot of money for new insulated boots last fall and wore them once when we had an open house and free hotdog day at our snowmobile clubhouse.
Mountaintech
Keep us updated. I would watch carefully to make sure ice does not separate it from the sled. It only seems to be a problem for some instances. If you thaw out your sled after riding its not a problem.
Thanks guys
Cat # 6639-452 should be white rear skid plate for 7000 models. Cat #6639-116 excludes 7000 models
5639-748 should be the front one.
Playing off trail in the fresh snow and there is not nearly enough heat to keep it clean or also when it's just sitting out in the snow with the motor off. I think the holes help when I'm cleaning the snow out before a ride or cleaning it out during a ride in lots of powder. Like anything, it's all about someones preference and the riding conditions.
I am making a hole big enough to poke bottle through for oil change at tank. Would make a mess otherwise.
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
I will continue to pull the skid plate mainly because once the oil is drained is the best time to have access to the chain case and I like to have a look to see whats happening in there.
If it's time for an engine oil change it's time for a chain case oil change.
