09nytro
I've had lots of these tanks off and from what I see there is really no baffle plates in the tank ... I would think on a MTX there should be so the oil doesn't move around as much ...do you have a dip stick or window , I can't remember whitch one came on the MTX ... I thought that's why they went to the dip stick tank because it's bigger , 1qt bigger to help this !!
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
The dipstick model tank does have a baffle that the window oil tank does not have. Maybe that baffle and the extra oil (4.4 quart) still doesn't make a difference when your cat walking though.
Sunvang
- Jan 14, 2009
- Telemark
- Norway
- 2018 Arctic Cat Hardcore EVO
2017 Yamaha Sidewinder BTX LE
I believe all 2015 and have dipstick? Mine does have a dipstick.The dipstick model tank does have a baffle that the window oil tank does not have. Maybe that baffle and the extra oil (4.4 quart) still doesn't make a difference when your cat walking though.
yamahaguy
Ride SAFE
- Apr 20, 2014
The early 15's did not come with a dipstick tank. We had one of each until I changed the SE tank out now they are both the same.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
I run extra oil and have never had my light come on. I run at the top of the sight glass then add a little more. If i see it get down to where i can see it i add a little. this engine holds a lot of oil in the valve train when running, I was told to run extra.
09nytro
Could the baffle be doing it then ? not letting the oil stay level in the tank and get alittle air under the baffle , maybe !!!
yamahaguy
Ride SAFE
- Apr 20, 2014
The baffle is across the top, about 3/4's the way up the tank. The idea of it is to keep the oil in the bottom 3/4's of the tank and the top 1/4 is more just air space.
iola
- Sep 24, 2015
- Kimmirut
- Sr viper stx 2015
mine 2015 stx red no dipstick
shagman
Vendor
- Feb 18, 2014
Run oil at top of sight glass or a little more.mine 2015 stx red no dipstick
yamahaguy
Ride SAFE
- Apr 20, 2014
Here is what it looks like:
http://www.ty4stroke.com/threads/is-there-a-definitive-answer-oil-tank.131830/#post-1199678
iola
- Sep 24, 2015
- Kimmirut
- Sr viper stx 2015
Witch one is better dipstick or no dipstick
Martens199
- Oct 1, 2012
- Saskatchewan, Canada
- 2008 Yamaha nytro 153 mcx190
2015 SRViper mtx se 162 mcx270
Did you call dean?Thanks, i will contact them.
Martens199
- Oct 1, 2012
Here is the fix.
There is an oil sensor that comes on when the sled is in upside down postion. So this is turning on when your sled is vertical as well. It's resistor block that these guys made to dummy the sensor.
That is not a fix. If the sensor activates the system it is obviously sensing a change in oil pressure or volume. The change in Oil pressure or Volume must be corrected not the sensor. Its working.Here is the fix.
Martens199
- Oct 1, 2012
Yeah he was saying there is 2 sensors on the motor. The one needs to stay put but the other they are delaying it with resistors. Yes it's not a fix. But it the only way to make the sleds rideable at the moment. I still that a redesigned tank would be best. Arctic cat had a fix where they delayed the light for 10 more seconds. But still not enough.
