ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Brent did you try the Ultimax already?
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Not slipping.....too much backpressure is making heat IMO
Mine did same.
Dan
Ran 6,2 yesterday. Still hot
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
Yup grenaded that belt in 300 miles
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Brent, are you breaking the belts on big trails(higher speeds) or corner to corner?
Where is offset at now? And have you recently checked it after each blow?
Remember stub can move on blow.
Hmmm.....I wish you had some Daltons just to test. I also snapped my Ultimax within 50 miles using STMs.
What helix you running?
Dan
Dan
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
Dan
Seems to be after a good long pull. Then 2 minutes later it goes.
Last belt blow it did change my offset by 1mm. I adjusted for that.
Blew ultimax in 350 mile and now 8dn in about the same mileage.
Making some adjustments in my weights as suggested by CM. See how that works.
37/35 helix
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Ok so you run a lower helix too, that is same as me. I doubt you are slipping up top.Seems to be after a good long pull. Then 2 minutes later it goes.
37/35 helix
Yeah see what adjustments do for you on this STMs. The very reason I went back to Daltons, I just like the simplicity, so hopefully the gurus here can dial you in.
Dan
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
Dan
I haven’t ran it up top in fear of blowing another belt! Trying to get the clutches cool first before doing more top end passes!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Brent do you have alot miles on the SRX yet? Just wondering.
Dan
Dan
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
Dan
Just over 1500 miles.
- 19K
