journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Mine is bone stock still and I have 5100 and change on the odometer. No belt issues yet. I towed a guy in for 20 miles too this week.
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700, 2023 Polaris Boost VR-129
- Niles, Oh
I remember an article in Snowtech Magazine from many years ago when Randy Nouis was comparing roller vs button clutches. The number he settled on was 4 deg additional angle that a roller needed over a button to be equal.Bad. No way were they bad, quite the opposite in fact. Buttons are what most of what the drag racers run in fact.
Just the fact that with a roller vs button, there is about a 8-10 degree difference in helix angle change needed.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I found more than double 4 degrees on the race track! I'm sure it depends on the power and conditions you are running. We were able to get a roller secondary setup down to the E.T. of the button if the traction was good. If you spun at all though on the pass, the roller would overshift dramatically and not recover well. Hence the reason you see drag racers using button clutches.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Cat green! $50 spring $100 belt. Garbage!
Ran it at 0,1 which was super hot. Then today ran it 9,1. POW 8dn grenade
Back to square 1 I guess
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
You guys are hard on your equipment lol
theewarrior
What primary spring you runningYesterday was an extremely good day on the trails for me. I'm honing in on clutching nirvana for my machine. Went back to the stock Yamaha secondary rollers and was able to put the weight back into the clutch arms. I messed around going back the the Dalton black/orange driven spring for a bit last week and no workie for me with either a 8JP or the 8DN, just like last year, slippage in the secondary, I could even smell the belt at times. I just can't run light weights or light driven spring setups on the big tunes, on the 240 its fantastic, but any more than that and I just can't. They just don't grip the belts for me, no way, no how. I corded a 8DN belt because I tried the light stuff again, the heat was so immense I end up with over 225* primary and belt temps after just one run trying it!
The heavy setup I can achieve extremely low clutch and belt temps using the 8DN. I'm up to 82.2 G in the Daltons and need more yet to keep RPM in check using the EPI purple set at 0-1. I keep putting more weight in on the 290R tune and it just keeps asking for more. My gosh am I loving this sled now! Going to end up at 83.5G in the Dalton arms today. The 8DN is holding up great now that I put the heavy package back in with the Yamaha secondary rollers. My god is this sled fast! No more light secondary springs, light weights or 8JP's for me anymore. I can finally say WOW, I am very happy, happy, happy with this sled now!
For those trying to run heavy springs on soft belts and getting hot temps, well that may not work that great and it may need a belt like the 8DN to work properly, I believe the whole package needs to work together as a team, even though you think you are running the correct RPM, that means nothing to the system performing as it should. I tried my setup with just a different set of secondary clutch rollers that shifted smother and faster, I had to lighten up the primary arms, I was too light on the arms up front at 78G and couldn't keep a hold on the belt in the primary at that point, I was chasing my tail. All I did was take out those rollers and go back to the stock Yamaha secondary rollers and put the weight in the arms and I got the balance back where the system was happy again. You just need to find that window where the primary, the secondary and belt are happy together.
On another note: I found using earplugs masks the clutch rattle, the exhaust and the wind noise. Imagine that.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
What is your tune and primary set up? You need horsepower and heavy clutch weights to run that cat greenCat green! $50 spring $100 belt. Garbage!
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
270 tune
Dalton blue primary
STM 60y fly weights
37/35 helix
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I have not used the STM weights that much. What is your total weight per arm?
Dr. FeeLGooD
Blew my second belt bone stock sled about 11oo miles now. Was doing 4 or 5 miles near wot on freshly covered hard pack. The belt was so hot I couldnt hold it in my bare hands. I guess I need to order the alignment tool. Not happy.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
78 grams per arm.
60 base , 7 heel, 4 mid, 7 tip
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
Running cat green spring at 6,3 now. Not as hot as 9,1 but still too hot for my liking. Going to try 6,2 next.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Brent,try your stock primary or a spring that is close to that,and remove weight off the heel,and run mid empty,add weight to tip,and try again. Where are your rpms with those ramps? I have had best luck with them at a washer on each side in heel,mid empty,and tip one tungsten and on other side 3 washers,gives me 8700 plus,and 38 stm helix cat white at 9-178 grams per arm.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
Thanks Pete. I’ll havw a look at that!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Not slipping.....too much backpressure is making heat IMOI ran the cat green spring today with 37/35 helix at 0/1 wrap. Both clutches were super hot and could feel belt slip . Couldn’t touch them. Backed it off to 9/1. Still hot but could hold my hands on them
Mine did same.
Dan
- 19K
