foolery
- Sep 12, 2015
- Cambridge
- 2016 Phazer.... plus a couple of 2016 Polaris 800's
I bought the OSP adjusted for my sidewinder.....
Need help with install order...
secondary clutch face \ insert machined spindle \ metal washer \ plastic thick ring \ machined adjusting ring \ tighten centre bolt then set belt height
or
secondary clutch face \ secondary clutch face \ plastic thick ring \ metal washer \ machined adjusting ring \ tighten centre bolt then set belt height
I can't find order of install of the aluminum water and thick plastic ring.
or
**sj**
the OSP metal washer eeds to be removed and stored in your tool kit...its for removing belts only
foolery
- Sep 12, 2015
- Cambridge
Thanks.... I thought that!
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
A pic might help guys out, Mine should be here soon i hope.
ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
Can any one tell me where you can buy one of these in Ontario?
Sent from my STV100-3 using Tapatalk
SWTURBO
Order it from OSP website got mine in 6 days to Ontario.
ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
Thank you for the heads up . Will do tonight yet.
- 48K
- 36K
