thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
Ouch did you put heat to them first?Recommend against removing the plate with 3 screws on the back of the clutch. That blue lock-tight is more like red. If you do, use heat. I snapped a head and ended up having to drill it out. Was not a happy day as a 30min job took half a day or more...
Not sure what your talking about there is no plate on the back of a secondary it is just 3 small bolts with washers as shims? They should not even have lock-tite on them they have to be removable to add or remove the shims.
Watch the video
http://www.ospracingparts.com/yamaha-sr-viper-belt-adjuster-with-float/
Watch the video
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Sounds like windage plates. Why would you need to remove those?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
earlier in this post they talk about removing the plate on the inside of the clutch I think that is what he is talking about.
4StrokeAddict
- Apr 13, 2015
- Michigan
- 2015 SR Viper LTX SE
Correct. You don't need to remove the plate. Just wanted to reduce the minimal weight and rotational mass associated with it. When I did it, was out of propane for my torch and didn't heat it up. Much regret and head banging
. Just word of advice from experience, heat is the answer if you choose to remove it. I recommend against it. I managed to get everything out and chased the threads with a tap just to make sure I didn't do damage with the drill bit. Seems to be OK. Just need to find a replacement screw to have on hand IOT return to stock if I so choose.
- Nov 29, 2009
- sabattus, maine
Is the TYOSP code still in use or has that expired? Planning on ordering this weekend. Thanks
onestopjim
TY Advertiser
- Feb 22, 2006
- Howell MI
- www.onestopperformance.com
TYOSP at check out get them for 69.99
onestopjim
TY Advertiser
- Feb 22, 2006
- Howell MI
on sale for 1 more month
- Nov 29, 2009
- sabattus, maine
Tried ordering. Don't think it went through. Got to the paypal check out and when I went to pay it brought me right back to the checkout page on your site
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
I sent you a massage looking for shipping price to Canada. My address is in the message.
Dirtbikekid1998
- Mar 3, 2013
- Maine
- 2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
Just ordered the belt adjuster and gauge mount can wait for it to come in!! and thanks for the $20 off!
Dave_RX1
- Feb 22, 2015
- Newton, Wisconsin
- 2014 Viper
2016 Viper
Just ordered 2 belt adjusters only got a discount on one which is better than none. Now to get new belts. Bring on the snow!!!
- Nov 29, 2009
- sabattus, maine
Tried again and it went throughTried ordering. Don't think it went through. Got to the paypal check out and when I went to pay it brought me right back to the checkout page on your site
nysnorider
Just installed mine yesterday.
Hope to tune on snow soon.
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
I sent a couple of e-mails now to www.Onestopperformance.com web site about the belt Adjuster and left 2 messages on this site for onestopjim but got no response.
