Blizzard24
- May 9, 2022
- Wallkill, NY
- 2009 Apex ER
2007 RS Venture GT
2008 Phazer RTX
I definitely will! Thank you!I have not heard back from him if I do I will let you know, can you do the same for me?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I had a discussion with UP bushman last year regarding his kit. Since he is no longer offering the kit, he gave me the OK to replicate it. I tested a few different materials this past season, but concluded that the stainless bushing and ski collar is indeed the way to go. I will likely be switching the offset spacers to a plastic as all the procross sleds use plastic. This should also help keep cost down as stainless prices right now are crazy high.
Dynomax666
- Sep 26, 2021
- Eastern
- 2006 apex
So are you selling these? I've got bushings that appear stuck inside.., if I rehash the bushing That the ski bolt goes through was 16mm and from what I can tell the spndle is 18 or 19mm? I tried tapping it out with an 18mm driver and heat no luck. I don't see a split in the bushing on either side.... And when I try to angle a punch in there it doesn't budge either. Next move will be hacksaw to make a split or just get a drill bit and drill... Not sure exactly what size od it is however?I had a discussion with UP bushman last year regarding his kit. Since he is no longer offering the kit, he gave me the OK to replicate it. I tested a few different materials this past season, but concluded that the stainless bushing and ski collar is indeed the way to go. I will likely be switching the offset spacers to a plastic as all the procross sleds use plastic. This should also help keep cost down as stainless prices right now are crazy high.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I am working on this yet. Should have kits ready this fall.
Dynomax666
- Sep 26, 2021
- Eastern
- 2006 apex
interesting. do you know the diameter of the spindle with bushing removed?I am working on this yet. Should have kits ready this fall.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
When I saw that UpBushman stopped making these, I just went and ordered the stock bushings for a basket case VL I'm currently working on. I may tell the owner that I may have to hang on to his sled a little longer to do this or just send it for now.I am working on this yet. Should have kits ready this fall.
Dynomax666
- Sep 26, 2021
- Eastern
- 2006 apex
What is the outside diameter of the bushings. I'm having a heck of a time removing these. I fear drilling is the next stepWhen I saw that UpBushman stopped making these, I just went and ordered the stock bushings for a basket case VL I'm currently working on. I may tell the owner that I may have to hang on to his sled a little longer to do this or just send it for now.
I think this is an old set of UP Bushman’s. .750 in OD.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
What were these kits retailing for at the end of his run? I saw a post from 2019 in which one member paid 135 shipped for 2 kits but wasn't sure if that did one sled or 2 sleds. Got some numbers back from machine shop so trying to figure out if cost effective to make. Looks like all new oem parts is roughly is around $74 list to do one spindle.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I now have a handful of kits in stock. Retail is going to be $150 per sled. Only notable change to kit is I opted for a plastic instead of stainless offset spacers to help keep costs down. All the vipers/sidewinder use plastic. I also increased the OD of the offset spacers a bit and lengthened them to eliminate the thin shim washers used with the OEM setup.
Dynomax666
- Sep 26, 2021
- Eastern
- 2006 apex
Do you have a diagram on how that goes? I think I'm kind of in a mess I created myself couldn't get stock bushings out tried drilling at 18mm. I think I'm going to have to make my own kit oversize to 20mm-16mm sleeve now. These spindles are awfulI now have a handful of kits in stock. Retail is going to be $150 per sled. Only notable change to kit is I opted for a plastic instead of stainless offset spacers to help keep costs down. All the vipers/sidewinder use plastic. I also increased the OD of the offset spacers a bit and lengthened them to eliminate the thin shim washers used with the OEM setup.View attachment 173987
FX Nytro Newbie
- Nov 19, 2023
- New England
- 2012 Fx Nytro and an old 04 Polaris xcsp
Is your kit direct fit for my 2012 FX Nytro 121" with Curve XS ski's?I now have a handful of kits in stock. Retail is going to be $150 per sled. Only notable change to kit is I opted for a plastic instead of stainless offset spacers to help keep costs down. All the vipers/sidewinder use plastic. I also increased the OD of the offset spacers a bit and lengthened them to eliminate the thin shim washers used with the OEM setup.View attachment 173987
