lb288smack
- Aug 20, 2020
- New York
- 2007 Phazer
2007 Phazer has sat for 6 years. I'm trying to resurrect her. Drained the fuel, changed the oil, replaced spark plugs, all that... it turns over but won't start. Engine light blinks but no codes. Any suggestions?
aproudcanadian
- Dec 18, 2016
- new brunswick
- 2020 ski doo 900t x
Is fuel pump cycling when you turn on the key?
x2 on the fuel pump.
lb288smack
- Aug 20, 2020
- New York
- 2007 Phazer
Yes, fuel pump is cycling as normal.
Is a blinking engine light without any codes normal?
I do not remember for sure on the light but another member was having problems with his injectors hanging up/staying shut on a sled that had sat for a few years.
Spray a little starting fluid in it. If it fires then you know it’s just not getting fuel. Light should not be blinking unless low on fuel or a code. Any code on dash?
pdiddy
- Oct 12, 2004
- Southern Maine
- '18 Vector 129", '18 Indy 600 SP
Not run for 6 years? Sled is starved for love!!! (And fuel probably as well.)
lb288smack
- Aug 20, 2020
- New York
- 2007 Phazer
Got it to fire up, BARELY runs. No chance in a idle. I'll have to check the injectors. Light still there.I do not remember for sure on the light but another member was having problems with his injectors hanging up/staying shut on a sled that had sat for a few years.
lb288smack
- Aug 20, 2020
- New York
- 2007 Phazer
Codes are 60 and 64 in diagnoses mode? Then nothing. I got it to fire (with a lil WD 40), but BARELY runs. No chance in a idle. But now it does fire up every attempt...Spray a little starting fluid in it. If it fires then you know it’s just not getting fuel. Light should not be blinking unless low on fuel or a code. Any code on dash?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Check the fuel pressure. The pump may be running but may have become permanently gummed up. Could also be the pressure regulator or the return system stuck open or leaking. If all that checks out, I'd pull the injectors and clean them.
lb288smack
- Aug 20, 2020
- New York
- 2007 Phazer
Pulled the injector. One was really gummed up. Sending out to get cleaned.Check the fuel pressure. The pump may be running but may have become permanently gummed up. Could also be the pressure regulator or the return system stuck open or leaking. If all that checks out, I'd pull the injectors and clean them.
glad you found it.
- 12K
- 26K
