Sprint26
- Nov 24, 2020
- Minnesota
- 2015 Viper XTX
Where is a good place to get a power commander?
RobX-1
- Coldwater, OH
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I have 3 standard PCVs in stock yet, as well as the turbo version that are PC6 PTI units.
ZTRACING
- Feb 6, 2018
- South Elgin, IL
- 2014 SR Viper XTX
2006 Yamaha Apex GT (Sold)
- South Elgin, IL
Do you have any of the Power Commander ignition modules for SR Viper?I have 3 standard PCVs in stock yet, as well as the turbo version that are PC6 PTI units.
- Apr 17, 2003
- Menno, SD
- Menno, SD
No I do not. Also the Ignition Module on the SR Viper models had a high failure rate, I wouldn't recommend running one.
ZTRACING
- Feb 6, 2018
- South Elgin, IL
- 2014 SR Viper XTX
- South Elgin, IL
Appreciate the info. Do you know of anyone that offers something to raise the rev limiter? I have one sled with the discontinued EVO flash that works awesome. Just obtained a 2nd sled that I would like to setup similar.No I do not. Also the Ignition Module on the SR Viper models had a high failure rate, I wouldn't recommend running one.
- Apr 17, 2003
- Menno, SD
- Menno, SD
There is no one that I know of that can reflash the ECUs on the Viper models any longer.
I have well over 15,000mi and 5?Years on My Ignition Module from you. Maybe guys weren't wiring them right.I paid special attention to grounding the PCV,Ignition and Pod300 on same lug right by fuse box. I love the maps you made for me using it. The stutter button has won me many races. Probably just from Psyching them outNo I do not. Also the Ignition Module on the SR Viper models had a high failure rate, I wouldn't recommend running one.
