- Sauk Prairie, WI
- www.ty4stroke.com
machj said:what secondary spring
Ancient chinese secret...LOL, send me a PM and Ill fill you in...BBY
byoffcr
machz I,ve been talking to Matt on this kit for 2 weeks now and what he told me was there is more than 1 spring he will be putting with the kit. It will be desided at the time of order since there is a difference in sleds and rider weight , also what it will be used for primarly. He couldnt say what spring would be used till then.. Hope this helps byoffcr
Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
Don't take this out of context but how does machining primary and secondary for overdrive help when you can put a turbo on stock geared and clutched APEX not machined for overdrive and produce 135+ mph on GPS ?
On gearing are you going 23 on top or 40 on bottom ?
- Sauk Prairie, WI
- www.ty4stroke.com
Reaper said:Don't take this out of context but how does machining primary and secondary for overdrive help when you can put a turbo on stock geared and clutched APEX not machined for overdrive and produce 135+ mph on GPS ?
because of a few things
1. You cant pull the stock gearing in an apex with 150 HP
2. Your clutches will only shift out so far in stock form.
Thats about as simple as it gets...BBY
Reaper
- Nov 10, 2005
OK, makes sense but if you can pull the big end number with stock gear with more HP then theortically the clutches can shift out to make this happen so why machine ? Just trying to get me head around it.
- Sauk Prairie, WI
- www.ty4stroke.com
Reaper said:OK, makes sense but if you can pull the big end number with stock gear with more HP then theortically the clutches can shift out to make this happen so why machine ? Just trying to get me head around it.
Guys, the apex is geared for 129 MPH. Problem is, with only 150 hp, youll never see it. You can take this for what its worth. It works, plain and simple...BBY
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
What is the rpm are you seeing with this kit???
byoffcr
About 10500 to 10600.
BADSLED
- May 13, 2004
- Syracuse, NY
How much of the primary is machined?? Some were known to create a mess if too much taken off.
- Sauk Prairie, WI
- www.ty4stroke.com
BADSLED said:How much of the primary is machined?? Some were known to create a mess if too much taken off.
Just enough and in the right places...BBY
BBY,send me a p.m. im interested in what u are saying,ive never machined a primary,the gear change u suggest is it a top 23 tooth,should i studd the track..thanx
SledFreak
- Feb 7, 2005
- Ontario. Canada
Then stick with stock and change the bottom gear to a 40 or a top gear to the 23. The bottom is the preferred approach. OR Get with Matts, The Speedshop kit, which is a gear change, machine stock helix and stock Primary clutch, in which he indicates is the fastest and Matt has also this against tested against all other kits and a stock sled. Also, you may even want to try a 22/38 gearing combo, which is what will be in the 07 RTX. You will have to buy a new chain and a 22 top gear and still have Matt machine the Primary Clutch and Secondary helix.Throttl Jockey said:So which kit, is gonna be the best for trail riding / trail racing, I don't care about drag racing or top speed, I just want something for 0 to 75 mph, ( mainly in the whoops and twists on the trails) and something that is gonna just be a little bit more snappy then stock.... Any suggestions.. OR would re gearing work?
Throttle Jockey
- Dec 12, 2005
- Fort atkinson,wi
- yamaha
I am leaning towards the Speed Shop kit as of right now, I went out and bought the wife a new leftover o6 Nytro, so now I don't have to worry about her wanting to get on the RTX anymore. LOL
- 10K
- 19K
