RocketmanROD
Does anyone make a kit so that i can use a 6205 bearing instead of the small ones that are on the sled and add fourth wheel
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
RocketmanROD said:Does anyone make a kit so that i can use a 6205 bearing instead of the small ones that are on the sled and add fourth wheel
there are lots of 4th wheel kits out there (one from Yamaha) including the wheel and spacers..... if that is what you were asking??
RocketmanROD
sort of the yami one still uses the small bearings and any other ones i found are for bilet wheels do not want those
Grimm
Best and cheapest way to do it is modifying the aluminum sheaves yourself and buying 4, 7" wheels with the 6205 bearing from Royal Distributing or local Dealer.
RocketmanROD
ok but is the shaft size not too small for 6205
Grimm
Same size axle, it's the width of the bearing that is different, ie. 6005 is 12mm wide, 6205 is 15mm.
RocketmanROD
ok but the inner diameter is different no?????
Grimm
Same inner diameter.
Grimm
Whoops! I just realized that the rear axle wheels don't use the 6005 bearing, but a 6004. Switching to a wider 6204 bearing will work in this case.
RocketmanROD
Thanks thats what i thought i would like to use a bigger diameter all around thats why i need a shaft. blowing lots of wheels??
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
B
How are you blowing the wheels?
RocketmanROD said:Thanks thats what i thought i would like to use a bigger diameter all around thats why i need a shaft. blowing lots of wheels??
RocketmanROD
bearing failures i have had ten sleds and never blown a bearing only have 1000 miles and blown 3
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Wow weird. I have about 3000 miles on mine this year with no problems. Wonder if you got some bad ones? They should last longer then that unless your running in all dirt. Good luck with the upgrade.
RocketmanROD
thanks will try try figure out
