ontarioyamaha
- Mar 26, 2017
- Port Perry, Ontario
- 2010 Vector ltx GT
2010 MXZ X 1200
- Port Perry
I found a simple fix to pretty much eliminate the loose steering on these machines.
Last summer I replaced every bushing in the front end and much to my dismay it did little to nothing to fix that play between the handle bars and the skiis.
Replace the found thin bushings in the ski spindle and the cross collar. Pictures below. I did it this week and it is mint!
They are a bit of a pain to get out and you need to be very delicate when you install but well worth the effort.
Nice fix, thanks for sharing. I will add this into FAQ.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
So to do both sides you would need 2 item #13 and 4 item # 27 correct?I found a simple fix to pretty much eliminate the loose steering on these machines.
ontarioyamaha
- Mar 26, 2017
2010 MXZ X 1200
- Port Perry
Yes that is correct, both sides
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
dmaxx
- Apr 5, 2006
- sw Michigan
- 2015 Viper RTX, 2012 Apex XTX, 2010 Vector LTX, 2000 AC Z-370..fast
- White Pigeon, MI
Just did this to the Apex. Parts were a little worn and this seems to take some of the slop away
- 47K
