rtx rollover
hypertxer
billerica,mass
i rolled it already i broke the tab on the head light on the side where it hooks to the frame. iwas wondiring if i could jb weld it or anything like that i dont want to spend $216 for a new one
I used plastic epoxy that seems to work well. As long as you have the headlight assembly installed correctly (not resting on tabs) it will not move around. Save your money!!!!
EPOXY works great !!
prep the area good with some sandpaper and clean with some acetone.
do not use a a 1 hour epoxy!!
make sure you let it cure for 24 hours in the warm house!!
should i take the headlight out or do it in the sled. idont think it will line up if ido it in the sled but will it be strong enough to put it on and install it again
