mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
He will need to lower the wastegate preload BEFORE installing the boost controller since the boost controller will not help him LOWER the preset boost level
FLYBYU
MulotTurbo said:He will need to lower the wastegate preload BEFORE installing the boost controller since the boost controller will not help him LOWER the preset boost level
Thats what were having him do now. So you legthen rod all the way out? Maybe it's stuck. The hose from the output of the turbo to wastegate actuator is leak free and has nothing in between it? Maybe it's the wrong actuator? I'm not sure whats the right part # for that but i'm sure someone here has it. Are you sure your at the end of rod thread on the wastegate?
machz69
is it easy to open the gate?.. I tried moving mine by hand and no way, you would really need to pull hard?..but it does open at 6lbs on an air guage but i will have to confirm with my boost guage. Mine is not hitting the tank. I moved it back.BigDog05 said:I know this sounds too simple, but did you disconnect the activation arm and move the waste gate by hand. Could it be stuck?
Try doing like i said, put an air gauge on it with air. set your compressor to 7lbs and see if it will open. This might help to find out if it's the gate or the actuator.
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
If you remove the actuator rod from the wastegate arm, the arm / wastegate should flop back and forth easily with NO resistance. If not, it is rusted and sticking and taking more pressure to actuate.
pdrmike
- Dec 13, 2005
- Berlin, WI / Ontonagon,MI
- 12 APEX'S 09 Venture GT
I had the arm off and it all moves freely, that is how I determined it was all the way open. I opened it all the way and adjusted the arm to keep it open, still 14psi with wastegate fully open. Boy, this is getting fun!
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
You have too much backpressure then! The wastegate can't dump it enough and it keeps driving the turbine.
machz69
Hey that's interesting. Never thought of that?.. that could be why I get a difference in lbs to open the gate with air pressure then when the motor does. So what would be the answer?.. a different spring in the actuator or exhaust?mbarryracing said:You have too much backpressure then! The wastegate can't dump it enough and it keeps driving the turbine.
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
As a total rectal extraction, I'd dare to say that the problem might lie post turbo and in the outlet / muffler? How much restriction do you have in the outlet?
Flow will take the path of least resistance (high to low pressure), if the exhaust pressure is the same on either side of the wastegate port as it is in front of the exhaust scroll, the exhaust will just keep traveling past the turbine... The purpose of the wastegate is to "dump" the exhaust pressure before the exhaust scroll but if it can't the back pressure will continue to drive the turbine.
machz69
I have the stock exhaust or muffle but i thought all the CPR systems ran on the stock muffler?
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
They might, maybe some baffle broke and lodged sideways or something stupid like that. Just a guess but you could always unbolt the outlet from the turbo and take a peak, etc.
Which way does the outlet face? Away from the gas tank?
I've seen a few rear mounts run without the outlets on a dyno for B/P development reasons... Unbolt it and rip it across the yard to see if the boost is reduced in conjunction with reduced B/P??? I'm grasping at straws here as I am not at all familiar with CPR's...
Droped my exhaust in the tunnel straight off the down pipe lost 2# of boost and sled has never ran better. (apex mnt cpr kit)
FLYBYU
There is a mod to stock exhaust that cpr reccomends but i just went right to excell exhaust. He wont able to drop the pipe, it will melt the tank.Something is stuck. that turbo is maxed out at that psi. the wastegate is not doing it's job
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Or it can't do it's job...
Definitely one or the other.
machz69
What is the mod that he recommends?FLYBYU said:There is a mod to stock exhaust that cpr reccomends but i just went right to excell exhaust. He wont able to drop the pipe, it will melt the tank.Something is stuck. that turbo is maxed out at that psi. the wastegate is not doing it's job
