STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
It is not the threaded tip that falls out of the cheap ones. It the whole end piece, threaded parts and all. Leaves you with nothing but the cable. They are not crimped on properly.On that note, I have also lost the tips from the duraflex as well. Nothing assures them staying other than loctite, even on name brand scratchers.
Between the lines designs has some nice mounting options for the Duraflex scratcher.
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Exactly my nephews pulled the crimped end right off the cableIt is not the threaded tip that falls out of the cheap ones. It the whole end piece, threaded parts and all. Leaves you with nothing but the cable. They are not crimped on properly.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
I ordered a set and received them today. Summer project to install them. Thanks for the suggestion!
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
No issues with them hitting anywhere after 3 seasons. I've had several buddies mount them in the same spot without issue thus far.
I was gonna edit the pic and crop out the wheel, as it is an easy trick that nets an extra 2 mph......lol...... but decided to leave it as a reference point to mount the scratcher. I didn't think anyone would notice, but not much gets by you. Lol
The wheels are ski Doo wheels, which are 1mm bigger than factory Yamaha wheels, but much more durable. They were the closest/best replacement I could find and I put them on all my sleds now.
PPD Idler Wheel, 141mm
OEM-style replacement idler wheels made with the highest quality. 141 mm O.D. Includes 6004 bearing, circlip, and bushing if required. For replacement bushings, bearings, or circlips, reference the part number listed under technical specifications (when
www.royaldistributing.com
These also work great, been running them for years now and they hold up good with minimal wear.
- 29K
- 33K
