Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
I found that peening the sheave next to the bushing (I do it 3 in spots with a punch) eliminated the bushing working loose on machines that seemed to have this problem. The little bit of material sacrificed each time you replace the bushing is trivial. This might be what cannondale27 meant by "stake on sheave next to bushing".
While I think that hot running clutches increase the possibility, it also happened on sleds that run cool clutches, lower HP machines and even new ones. I gave up trying to figure out the root cause and just went with making it stay in place.
fwiw - I found that Loctite sleeve retainer helped some but others still worked loose. Peening hasn't failed yet.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
So you peen on both sides of the bushing?
My new jackshaft and bearing arrived today so time to re-assemble.
RAMSOMAIR
Hope that works for you. It didn’t for me. I used green bearing retainer and used a punch and made 3 punch marks on each side of the bushing.So you peen on both sides of the bushing?
DMCTurbo
- Nov 12, 2005
I'm going to try and check every km for a bit to make sure it stays put. If not I'll order a new sheave. Damn money pit.Hope that works for you. It didn’t for me. I used green bearing retainer and used a punch and made 3 punch marks on each side of the bushing.
RAMSOMAIR
Indeed they are. Hope it’s not back ordered if you need one. I know where there might be a used one. Let me know
DMCTurbo
- Nov 12, 2005
I'm hoping I don't need one but will keep that in mind. Thank you.Indeed they are. Hope it’s not back ordered if you need one. I know where there might be a used one. Let me know
DMCTurbo
- Nov 12, 2005
New bushing installed. Used bearing retainer and also
let it seep in behind after install. Peened both sides of the bushing. She didn't move today after beating on it. Do you think I can relax now or should it always be in the back of my mind?
RAMSOMAIR
Be afraid, be afraid! Just kidding. Who knows eh?
SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
New bushing installed. Used bearing retainer and also View attachment 159237 let it seep in behind after install. Peened both sides of the bushing. She didn't move today after beating on it. Do you think I can relax now or should it always be in the back of my mind?
I did the same. Pressed in new bushing, put some loctite retainer on both sides, peened both sides.
We got 14 inches of snow here in Eastern Long Island.
Rode about 20 miles on ice roads....not a good testing location.
Held up, my Son took a rip and got it up to 100 mph.
Can't hold my breath very long! Too old!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Relax you did it right with that sleeve retainer!!!New bushing installed. Used bearing retainer and also View attachment 159237 let it seep in behind after install. Peened both sides of the bushing. She didn't move today after beating on it. Do you think I can relax now or should it always be in the back of my mind?
titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
Agreed, Did the same with my secondary after the bushing came out and messed up the jackshaft bearing. 3 small dimples on the backside, won't happen again..
DMCTurbo
- Nov 12, 2005
Thanks for the advice... much appreciated.
radianguy
- Jan 1, 2007
Where would one find an oilite bushing for the driven clutch?Exact same thing happened to me last winter. Pictures look the same. First time that I have ever been left stranded on a Yamaha....can't even blame it on Cat DNA....Yamaha clutches. I installed a new replacement bushing with Loctite and it started to move so I am going to try an Oilite bushing instead.
View attachment 159041 View attachment 159042 View attachment 159043
Turboflash
- Mar 18, 2019
- Southern MN
McMaster-Carr?
