![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
With the belt off, From the outside of the secondary fixed sheave, to the edge of the primary fixed sheave, measures 68.2 mm.
Really! Got any pictures?
![Worthless :worth: :worth:](/styles/default/xenforo/smilies/worthless.gif)
![Horsehockey :crap: :crap:](/styles/default/xenforo/smilies/horsehockey.gif)
ssgzag15
I figured out what's going on here, my caliper that I use at work has the inside and outside jaws aligned, the one I am using at my shop does not, ![Dunno :dunno: :dunno:](/styles/default/xenforo/smilies/dunno.gif)
That being said, the real distance was initially 60.1 mm, I removed the shim and ended up with 59.1, gonna try her there.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Machine 2 mm and put washer backI figured out what's going on here, my caliper that I use at work has the inside and outside jaws aligned, the one I am using at my shop does not,
And throw that caliper in the bush after smashing it!
Fast
- Sep 25, 2018
59.1 is fine, been running that since new no issuesI figured out what's going on here, my caliper that I use at work has the inside and outside jaws aligned, the one I am using at my shop does not,
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
What does the Hurricane alignment bar set offset at? Measuring it pretty easy with right tools.The perfect spot is to get a Hurricane clutch alignment tool and you will be bang on my past experience IMO.
thanks Pan
ssgzag15
It goes in between the sheaves to give you a true 'center to center' reading, we are measuring from the edges where a belt never goes.What does the Hurricane alignment bar set offset at? Measuring it pretty easy with right tools.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
The edge and center are both accurate ways of setting offset as long as the parallel of the motor and Jackshaft are good. If the parallel is off the Hurricane tool is better and gets you closer to a good alignment.
Instead of measuring at the outside edge of the primary you measure at the centerline of the primary. If the primary is cocked a little one way or the other, measuring at the edge of the primary will be off but not if you measure at the clutch centerline. Also the tool is pinched between the secondary which provides a simulation of a straight belt comming off the secondary extended out to the centerline of the primary, not the edge of the primary, which could yield a different measurement if the clutches were not perfectly parallel.
ssgzag15
I remember setting up parallelism a little offset on the old race sleds to take into account the clutches pulling together under full load, being that these sleds are torque monsters, is any consideration given to this effect when under full load?The edge and center are both accurate ways of setting offset as long as the parallel of the motor and Jackshaft are good. If the parallel is off the Hurricane tool is better and gets you closer to a good alignment.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
No they do not account for torque pulling in the clutch center or shifting the engine off parallel. The mounts are much stiffer than the old sleds but a tuned Winder will move the motor somewhat, hence being on the low side of offset helps account somewhat.
I did a test where I took off my clutch and put a dial indicator on the motor. With the long clutch bolt screwed into the engine. With a 10” piece of pipe on the end of the bolt I could fairly easily move the motor around .030~.040” then it seemed to get stiff fast. No matter that’s enough for me, I made a torque link to help hold my engine straight. This was a huge problem with the Cat 1100 turbos, so I wasn’t taking any chances.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
ssgzag15
That should be a kit offered by some race shop....View attachment 157288 If the engine twists clockwise it will actually push the centers further apart.
yamahahaapex
59.98mm without a spacer. take the clip off and would be around 58.5mm. been running just fine at 59.98mm. Belt looks fine, not much for dust.
- 50K
- 33K
