I hope the rev limiter is raised on this engine. Hitting the rev limiter at 9150 with turbo is not so nice for the engine. So i hope the rev limiter is higher now, At least 9500 rpm .
The Nytro was set at 9250 rpm
And Viper at 9150 rpm that is to low.
I now the clutches isnt suposed to go over 9000 rpm but, there are snow conditions that can be so you hit the rev limiter at 9150 rpm and then the valve cap can come loose.
I just checked last night with my source and they are saying 9500 rpm.
GeFeldz
- Jan 27, 2009
- Sweden
- 1990 Aktiv Alaska XT, 1987 Ski-Doo Escapade, 1991 Polaris Indy Supertrak, 2011 Yamaha Apex XTX 1.75
Mcx says a tuning kit is in the works with about 250 hp using the stock turbo, they'll probably make a bigger kit with a bigger turbo as well!
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Perfect.
Thats what I run my MCX 290 Apex at for hp 90 % of the time.
EVO 1
- Jan 27, 2013
- Steamboat Springs, CO/ Somerset WI
- evopowersports.com
- 17 Sidewinder XTX, 17 Sidewinder MTX, 15 Viper MTX, 13 M1100T
- www.evopowersports.com
There is a bit of a difference here. Because this is a factory designed turbo system, it will have different cams. The Viper/Nytro engine had high revving cams which would make more and more power up to about 10,000 rpms. With that said, you can be sure we will be exploring the power characteristics of this engine and if it will be worthwhile to raise the rev limit above 9150.
EVO 1
- Jan 27, 2013
Hmmm.
Looks like that IHI Turbo should be good for 16psi boost give or take.
Maybe even as high as 21.
[Assuming I can read the chart correctly on that Turbo & the info on some of the car forums is accurate.]
The IHI turbocharger should be good up to 22 lbs no problem.
tapex_07
- Feb 15, 2009
- '10 Nytro MTX SE IMPULSE 174x3 *sold*
'14 Viper XTX SE MPI 141x1.3
'07 Apex RTX SC2 MPI 137x1.25
You wouldn't happen to have a link to that graph?Hmmm.
JustBoostIt
Vendor
- Apr 25, 2007
- Lloydminster, AB, Canada
- Evo turbo M7000 162 custom
Cat engineers I talked to said it was the same turbo as the 1100 had, implying the same cartridge even. It was good to about 17lbs before some heat soak started if that is true.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
That will be more than enough for most of us !!
Riceburner
- Apr 14, 2003
- N.B. Canada eh
Good info, Thanks.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
No I don't. Sorry.
It was a chart showing the specs for various IHI Turbos. not a graph per se.
The info on the forums was gleaned from a Subaru forum if I remember correctly.
Google was my friend .
Info from the Vendor & Advertiser above seem to back up what I found online. [ Great news IMHO]
**sj**
whats the gearing coming with? and how many plates wide?
Riceburner
- Apr 14, 2003
- N.B. Canada eh
Check out the Yamablog post from yesterday SJ.
Chris posted that all up.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
15 wide.....rtx/ltx coming with 21/41
Dan
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
the new system is set to handle 12psi,is that what it is stock or?
Riceburner
- Apr 14, 2003
- N.B. Canada eh
Not that stock. Likely 6 ish psi stock.
Educated guess tells me that Chris means the engine will handle 12 psi on likely 91 octane as it comes from the factory as I believe the Turbo can put out quite a bit more than 12 psi .
- 46K
- 11K
