CustomApexMan
Machzrobbie I bought your apex supercharger kit off here a while ago but anyway I'm running the mcx 270hp kit now on viper it just rocks only problem is it does not run to its full potential unless the air cleaner is through the hood
Studroes144
What does mcx use for an exhaust on standard kits? Is it a quiet exhaust or free flowing loud one? I had an exhaust made for my stage 1 mpi using a big core muffler, very deep sound! The sled is going to be getting dynoed here fairly soon, first thing we're gonna do is set it at 4.5 pounds and run it with the mpi quiet muffler and then swap out for the new exhaust without making any changes and hopefully making a nice broad gain. Shooting for around 10 pounds so the quiet one wouldn't cut it as I'm sure it would be too restrictive at those boost levels.
CustomApexMan
It's not very heavy and sounds very close to stock my friends keep telling me to get a pipe on it but I like it quite
Studroes144
What type of boost do u run?
CustomApexMan
15psi or over gauge only reads points so in between 15-16
machzrobbie
What kinds of gains did you get
machzrobbie
It's a fairly straight through muffler, you can see the inlet pipe inside looking through the outlet, but it's quiet.
CustomApexMan
Well I was not very impressed with the performance of the kit after comming off the apex I knew there was no way it was 270hp had too much fuel and not all the power. Dealer did not want to help or know how to, got ahold of a dealer out west and he said put it through the hood. After that I bet it picked up 30hp could not keep it off the Rev limiter, there is no comparison between in and out of the hood
Dealerjohn
- Mar 26, 2010
- Labrador
- 2015 MTX Viper, XTX Viper, 2001 SRX 700
One more question, the dealer sold her an autometer boost gauge as well. What's the verdict on those? Should I keep it?
Anyone?
Do a search under Studroes. He had some trouble with one brand. Not sure if that was it. I really like Innovate. Running a AFR on my NA. Have heard nothing but good things about them.
machzrobbie
Is
Is it a mechanical gauge??? It all depends what you want, a mechanical gauge can be hard to see exact boost level
Anyone?
Aem was the guage Studroes had problems with I believe. Fogged up bad.
Dealerjohn
- Mar 26, 2010
- Labrador
Is
It's not mechanical, I'm not sure if it shows a decimal point though. It looks to have 3 places for numbers though.
CustomApexMan
Aem has alot more problems than fogging up they have horrible sencors mostly the boost vac sencor
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
I had huge issues with fogging in Mesa. I installed the gauges in a +10C environment and took them outside. I have since left them outside in -25C outside with the bezels off and put them back on with a little DiElectric grease on the theads. Clear as a bell.
- 34K
