slimjim2525
Why are you taking apart a brand new sled? She doesn't get that these things aren't gas and go. LOL. SO I put in a 4th wheel kit, hose protectors, rollover bypass kit, DMC top gear, welded tensioner roller, brass shift fork pads, driveshaft saver, upnorth tech bracket for gas, oil tank gasket, rear tunnel savers, tunnel saver kit, seat screw, belt adjuster, and padded fuse box in front. Still have to do ice scratchers, wanna replace rear axel with solid one piece, one nut axel, belly pan protector, and rivnut lower panels. She just doesn't get it.
slimjim2525
slimjim2525
Was able to resize one pic to upload. But resized them all and none of the others will load, says file too big.
slimjim2525
sab2022
I didn't see Muffler Bolt change-out to hex with nickle anti-sieze.
slimjim2525
Yup, did that too. Put chain case protector on as well. And, put on AMPS mount for GPS.I didn't see Muffler Bolt change-out to hex with nickle anti-sieze.
slimjim2525
I am not pleased with the rear axel in this thing. One solid piece but has 2 bolts, one on each end. So, the left side if frozen can loosen the bolt when taking off. I have seen it happen on an Apex when someone had the axel placed right to left.
slimjim2525
Come to think of it, almost every problem with these sleds I have had on my 2018. It has 14,800 miles on it, and for the most part has been pretty bullet proof. The 2 things that actually ruined a trip could have been prevented by being proactive.
These were caught before any problems.
Worn top gear>>Check. New DMC gear installed
Loose bolts in tensioner>>Check. Caught when chaincase opened, welded the bolt.
Worn Driveshaft>>Check. New driveshaft installed. driveshaft saver installed.
These ruined trips
Broken tab off bottom of chaincase after hitting big G-out. Lost gear oil unknowingly, and sled ground to a stop.
Frozen rollover valve, blew out oil tank gasket and lost 3 quarts of oil in 10 seconds. Ruined Quebec trip 3 days early.
These ruined trips
Clintww
- Mar 6, 2022
- Central MN
- 2001 SXR. 2005 RX1. 2017 Sidewinder
- MN
What is meant as to padded the fuse box? I haven't seen this one.
Fords4life
- Dec 7, 2021
- South Dakota
I believe he means, between the fuse box and base it mounts on, have been wires chafed between the two, i used a piece of rubber inner tube between mine.What is meant as to padded the fuse box? I haven't seen this one.
NYTurbo
what’s up with those black plates on the rear suspension front mounts ?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
You should still be using the large oem washer on secondary bolt. It prevents adjuster from backing off if cinch bolt not tight
stgdz
- Mar 27, 2021
- Buffalo MN
Edit
slimjim2525
OK, I actually wondered about that.You should still be using the large oem washer on secondary bolt. It prevents adjuster from backing off if cinch bolt not tight
slimjim2525
Yes, this. Protect the wires from rubbing on the metal. I used a thin piece of foam padding.I believe he means, between the fuse box and base it mounts on, have been wires chafed between the two, i used a piece of rubber inner tube between mine.
- 36K
