Those bolts have been known to rip through the tunnel. Those plates reinforce the area to prevent this.what’s up with those black plates on the rear suspension front mounts ?
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
I agree with your wife, I dont get why either!Why are you taking apart a brand new sled? She doesn't get that these things aren't gas and go. LOL. SO I put in a 4th wheel kit, hose protectors, rollover bypass kit, DMC top gear, welded tensioner roller, brass shift fork pads, driveshaft saver, upnorth tech bracket for gas, oil tank gasket, rear tunnel savers, tunnel saver kit, seat screw, belt adjuster, and padded fuse box in front. Still have to do ice scratchers, wanna replace rear axel with solid one piece, one nut axel, belly pan protector, and rivnut lower panels. She just doesn't get it.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Those plates won’t stop it, get a better centre spring and heavy duty cross shaft like hurricane sells.Those bolts have been known to rip through the tunnel. Those plates reinforce the area to prevent
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
You're kidding, right? Ride your Apex 500 miles a year, and yeah you will have no problems. Ride a sidewinder 5k miles a year without preventative maintenance, you will have an issue pop up. Move along.I agree with your wife, I dont get why either!
Basic physics. I won't explain.Those plates won’t stop it, get a better centre spring and heavy duty cross shaft like hurricane sells.
hellflyer
- Dec 2, 2008
Holy #*$&@ thats gross. I put the BOP's HD cross shaft in as well.The shaft is the problem
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I have had the tunnel crack in that area without bending the cross shaft.
How the F hard are you guys riding these things to break the cross shaft, and fold the tunnel? LOL. Man, I'm a whimpy rider apparently. LMAO.
Turboflash
- Mar 18, 2019
- Southern MN
I've seen many sleds with hairline cracks radiating outwards from the mounting hole. These BOP plates reinforce the mounting area and prevent that.what’s up with those black plates on the rear suspension front mounts ?
Turboflash
- Mar 18, 2019
- Southern MN
BOP sells a nice stainless steel cross shaft to replace thhe stock aluminum one.
hellflyer
- Dec 2, 2008
The stock cross shaft flexes cuz it's too thin that's what causes a tunnel cracks.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Yes but those plates will not stop the damage from a broken cross shaft. Seen it . The issue is a weak front spring allowing the really short front shock to bottom destroying itself. Now you are hammering that wimpy cross shaft, it’s gonna break . Ive replaced and rebuilt dozens of these shocks and until you put an adequate spring and crossshaft in there you’re on borrowed time. Unless you weigh160 lbs soaking wet. Checking that shock should be done frequently.I've seen many sleds with hairline cracks radiating outwards from the mounting hole. These BOP plates reinforce the mounting area and prevent that.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
No I'm not kidding! average 3000 - 4000 miles per year on my Apex!You're kidding, right? Ride your Apex 500 miles a year, and yeah you will have no problems. Ride a sidewinder 5k miles a year without preventative maintenance, you will have an issue pop up. Move along.
- 46K
