out-front-Y
Was out at a radar run 1000' run 20psi and a stm rage eight clutch with a 54-48 helix wh-wh spring at 3-3 was running 24-33 gearing was not pulling after 600' and could hear rpms go up and then rev out like it blew a belt.
clutches look good and were cool . So i put stock gears 24-38 in it and it pulled
better but did the same thing now at 800' . changed belt cleaned both clutches same thing you would
swear it blew a belt every run.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
belt starter to slip.
nees LESS cam angle on top to sqeeze that belt!
out-front-Y
took my secondary and i melted groves in the bottom of it may be my
white spring is beat.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
I'm not racing, but I've had that problem on my trail sled running a Dalton 54/48 and a white spring at 60 degree, when climbing steep inclines and waterskipping the secondary could not hold the belt. Last year I ran a Dalton 56/46 and a red Dalton secondary at 80 degree, problem gone no more slippage to speak of.
out-front-Y
Will the shock wave helix work with 20 psi of boost?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Get the multi angled version.
- 7K
