Loc Tro
- Jan 24, 2014
Spit my track today! Track had 8-10k miles but looked mint. Just added drivers that turn track through the windows 200 miles ago and now this!
How do I determine what pitch track and drivers I have?
Was hard on it today heat cycling brakes, belt and track all day on and off gas and brakes in the trails.
Got to straight away and pinned it! Got to about 80-90mph and BANG sounded like I broke my chain but was track…
Loc Tro
- Jan 24, 2014
Weak old track or new drivers causing the issue do you think?
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
weak old track IMO I never run a track past 6000 miles.
![](/styles/admin.gif)
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
I have almost 11k on my 11 Apex 144 track, and over 8k on my 121 track on my 09 Apex without problems. Also have studs in both.
Fast Lane
- Feb 6, 2020
- Winnipeg
- 2007 Yamaha Nytro ER
- Winnipeg
My Nytro just turned over 10,000 kms. I’m starting to loose lugs. It may not be just the miles on the track and maybe age catching up to it too. The outer rubber is just starting to come off showing the cords on n one spot.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
During my preseason I look at the track. With stroke last Feb I only did 1k till then, usually do 2,500k each season. At the 1,200k mark this season so far, should check my track a little more often I guess now that miles are adding up.
i got roughly 14000 mi on the 2nd track on the 11 apex xtx as the 1st one got cut while riding. it started loosing the lug tips on the ripsaw. the composit 1.5" lug i have on it now has about 8000 mi and is holding up pretty well as it is in better shape than the ripsaw II that is on my 16 with less milage. if you can see the rods in the track, it is past toast and not even worth fixing.
kinger
Track pitch is distance between lugs 2.52" was std for decades, now you can get 2.83, 3", etc. So measure yours. On extrovert drivers measure tip to tip, they should match your track. Looks for any where around the holes in your track that blew see if you can find any clues there.
Glad you are ok, this is my single largest fear, popping a track on my 500hp sled that suddenly puts me in a barrel roll or a tree because you have no brakes.
- 41K
