snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Dan,not sure what either one of his springs have for rates,but I can tell you his red/black secondary spring is a lot longer than stock and is just 4 coils vrs 5 for stock,and has a lot of side pressure,i had all I could do to compress it to install nuts,and I only have it on 40 degrees,i just wanted to get it installed,i will wrap it to 60 or 70 once I get the beast back togeather.Interested on feedback of Allens kits, I think he may be the only one to have a helix/secondary spring in his kit at this time. And I like that he uses STs, nice weights.
Dan
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Version 3 powertrail is leaner and revs higher
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
TD told me 89-9000rpmVersion 3 powertrail is leaner and revs higher
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Thanks Pete...Dan,not sure what either one of his springs have for rates,but I can tell you his red/black secondary spring is a lot longer than stock and is just 4 coils vrs 5 for stock,and has a lot of side pressure,i had all I could do to compress it to install nuts,and I only have it on 40 degrees,i just wanted to get it installed,i will wrap it to 60 or 70 once I get the beast back togeather.
I have been back and forth with Dale for several weeks now on when he will have his new SW secondary spring. Dales is being purpose built for what we think the SW needs. IMO this is where the clutching is lacking. The poochy bottom and low/mid corner to corner stock clutching is just a slug. I often wish we had a compression secondary with the plethora of compression spring rates avail that BRP gives us...Running a high start rate compression secondary spring makes high rpms in trail and would put the turbo more in play.
Im not sure a torsional spring can have as high of a side force, but hoping to get more of them to test with. Do you know if Allens new torsional is just something "off the shelf "? I have spoke with several who have tried all the highest rate torsions they could get their hands on, and none seemed to have enough side pressure. It sounds promising with more length but less coils, Allen knows his stuff and im sure has got it working well. I would like to see him have more test time for sure.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Yes I hear ya Dan,i don't have a clue where this red/black spring came from,but I have a feeling it is one of cats old ones or he had it purpose built,i do remember him telling me he had an older cat spring he was working on,but he did not like the offset tangs,and I have to agree,it was just so weird trying to align one,when you were guessing,i tried one of my old 4 coil offset springs before I got his kit,and it was funky,and did not lay flat on stock SW helix,now this one still does not sit flat on Yamaha secondary sheeve pocket,but does lay flat on the helix he sent me. Right now it seems I have a set of STM weights that may be 4 gram heavier than they should be,if 76-77 grams is target. Allens instructions don't give stats on weight oof loaded or unloaded ramps,just how and where to load them with each washer or tungsten piece.
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
TD powerful run double tungsten in tips, I told you incorrectly @deekersrx700
DMCTurbo
- Nov 12, 2005
Ok great thanks for letting me know...TD powerful run double tungsten in tips, I told you incorrectly @deekersrx700
DMCTurbo
- Nov 12, 2005
OK loaded them up with tungstens in the tip, will report back after Monday what rpms I'm seeing..
DMCTurbo
- Nov 12, 2005
Wow lots of snow in Cochrane!!
So my rpms are 92-9300 with 2 tungstens in the tip. Need to add more weight, power trail really pulls like a freight train. Super quiet has an awesome sound. Seen 190 on speedo in short burst, previous best was 178 in better conditions, can't wait to get this beast on a hard packed rail bed. Thanks TD!!
75northface
- Oct 26, 2016
- Sudbury, Ontario
- - 2017 Sidewinder XTX SE
- 2016 SR Viper LTX DX
- 1997 Mach Z
Pics of that Cochrane snow please. Need some motivation lol
DMCTurbo
- Nov 12, 2005
I stepped off the sled next to the trail and sunk to my knees, fresh 6" on the trail today!Pics of that Cochrane snow please. Need some motivation lol
PowderFalcon
Pinnin' it!
Motivation from Sudbury?!?! I am 4 hours south of you guys and i'd be there in a second if i could take the time off to make the 8 hour drive!!! lol
75northface
- Oct 26, 2016
- Sudbury, Ontario
- 1997 Mach Z
Nah. No way! Don't believe it!
I'm jealous - enjoy it. Should be getting some in Sudbury this week (fingers crossed).
My dollar$ spent per miles ridden ratio just plain sucks right now lol.
PowderFalcon
Pinnin' it!
I agree!! costly year especially with a new sled! haha. I see 10mm of rain in the forecast your way, but snow and cold weather to follow. fingers crossed indeed!
- 46K
