razor_220
- Dec 21, 2012
- Saskatchewan
- Yamaha Nytro X-TX(sold)
Yamaha SRViper X-TX(sold)
Yamaha sidewinder B-TX
Changing bearing on stub shaft, when i install new bearing does it go all the way down to the bottom or is there a bit of gap?
Forgot to take a picture before i removed old one!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Tight no gap!!
Don't forget to use retaining compound
razor_220
- Dec 21, 2012
- Saskatchewan
Awesome!! Thxs for replying Yamamarc!!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
No prob!!!!Awesome!! Thxs for replying Yamamarc!!
Once you have it back together check your clutch offset to make sure you are still within spec
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Anyone have pictures of stub shaft flush and not flush? This way it will give a visual of what it should and shouldnt look like.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
This bearing got pushed in slightly. I put a green mark at the small gap. I was able to slide a .050"(1.27mm) feeler gauge between the outer race of bearing and the seat
Turboflash
- Mar 18, 2019
- Southern MN
If you do a search on this forum, there have been multiple posts of such pictures by several members.Anyone have pictures of stub shaft flush and not flush? This way it will give a visual of what it should and shouldnt look like.
SideHogger
- Apr 16, 2016
- upstate ny
Thank you Turboflash, Yamamarc.
