Turboflash
- Mar 18, 2019
- Southern MN
Haven't heard of failures at all since 2017. Although I admit I have regreased mine.I thought you might say that. Typically what is the life expectancy of that bearing.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Have you opened it up? It's like a heavy waxed based grease. Looks more like candle wax. Besides, mines was full at the time. I'm guessing 10k or more of grease life expectancy. Probably should have used it elsewhere on the sled. Lol.Haven't heard of failures at all since 2017. Although I admit I have regreased mine.
Turboflash
- Mar 18, 2019
- Southern MN
Yes, hi temp, hi rpm grease. Bearing is turning 9000 rpm.Have you opened it up? It's like a heavy waxed based grease. Looks more like candle wax. Besides, mines was full at the time. I'm guessing 10k or more of grease life expectancy. Probably should have used it elsewhere on the sled. Lol.
Doc Harley
- Oct 17, 2016
- Here & there
Is there a specific grease you use?Yes, hi temp, hi rpm grease. Bearing is turning 9000 rpm.
Turboflash
- Mar 18, 2019
- Southern MN
I'll see if I can find it in my notes. Believe it was Aeroshell #7 airplane grease. Temp range -99 degF to +300 F. I'll confirm.Is there a specific grease you use?
Doc Harley
- Oct 17, 2016
- Here & there
Turboflash, question....if you hold the housing with one hand and move the shaft side to side with other hand, should there be a slight amount of clearance/tolerance felt?I'll see if I can find it in my notes. Believe it was Aeroshell #7 airplane grease. Temp range -99 degF to +300 F. I'll confirm.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Only possible movement that would be felt would be in the bearing itself. Can’t imagine there should be but god knows .
Doc Harley
- Oct 17, 2016
- Here & there
Yep...that's exactly what it feels like. Brg & cage itself. It's not horrible, but definitely noticeable. I've never even thought to play with it, as I sit here and wait for knockoff.Only possible movement that would be felt would be in the bearing itself. Can’t imagine there should be but god knows .
Hmmm....9,000rpm & this little wobble. Lol. Maybe some I will pipe in, as I have no way to measure run out, or what's acceptable.
Doc Harley
- Oct 17, 2016
- Here & there
NYTurbo, the feedback I'm getting is that it's okay. So I'm assuming, once it's sitting on its axis, it's good to go.
Turboflash
- Mar 18, 2019
- Southern MN
Yes. You're feeling internal clearance in bearing. It's a C3 fit.Turboflash, question....if you hold the housing with one hand and move the shaft side to side with other hand, should there be a slight amount of clearance/tolerance felt?
Turboflash
- Mar 18, 2019
- Southern MN
Believe me - as bearing runs it heats up and the balls get bigger in diameter. Both races also "grow" due to thermal expansion. Gotta remember this bearing gets heat from crank/crankcase, and primary clutch. When you're out riding this bearing is turning what, 5-9000 RPM? Once it's at operating temp, there wouldn't be any "wobble" in primary clutch or stub shaft. Well, maybe technically there might a few millionths.Yep...that's exactly what it feels like. Brg & cage itself. It's not horrible, but definitely noticeable. I've never even thought to play with it, as I sit here and wait for knockoff.
Doc Harley
- Oct 17, 2016
- Here & there
I don't like the thought of putting something broken back in. Haha...
Thanks for the explanation!
Doc Harley
- Oct 17, 2016
- Here & there
Ok, for the members who have installed the knockout kit, tell me the coolant temp you ran the motor to B4 shutting off the sled?
Note: just asking...
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Anyone put one of these in a 1049 ntyro yet?
Doc Harley
- Oct 17, 2016
- Here & there
When I responded to you a second ago I wanted you to understand I do have the same shaft as the '18 and upAnyone put one of these in a 1049 ntyro yet?
