Synergy turbo kit
summitking
Lumby B.C
Heres some pics of a new turbo kit on the market for the apex . it runs a gt 30 ball bearing turbo and a external mounted waist gate. This turbo kit is definatly different that all the other turbo kits on the market. if you guys need contact info let me know and ill hook you up.
http://s43.photobucket.com/albums/e371/ ... h=imgAnch1
http://s43.photobucket.com/albums/e371/ ... h=imgAnch2
http://s43.photobucket.com/albums/e371/ ... h=imgAnch3
http://s43.photobucket.com/albums/e371/ ... h=imgAnch4
you may have to copy and post the like to your server.
Looks inovative, but why proto type it with a gt30, that turbo will do close to 500 hp and being a rear mount it will take time to spool.
looks like a lot of additional weight to me
looks like a clean set up, just not sure why they went with the gt30, especially on rear mount, will take longer to spool and I don,t see it having anymore usable hp. than the gt2871, but some people think the gt2871 is too much so each to his own, good to see more competition.
sled
Actually the gt 30 they are using is a ball bearing turbo and with it and the combination of it and a external mounted waste gate it spools about the same as a mcx apex rear mount. The kit is goign to be a bit heavier then most kits but it is also making more power. We do not have any dyno numbers yeat but we will keep you posted should have them soon.
External gate can use a tighter cartridge or turbine housing with a better flow characteristics. The external waste gate if he chooses to use an EBC (electronic boost controller) will allow him to run harder to full boost before blow off. You can actually hold the valve shut on the tial wastegate right until full boost is achieved instead of blowing off early. Or starting to leak close to full boost. External gates are also way better in terms of controlling boost creap etc.. not sure if thats a problem on a sled or not is sure is on cars.
sled
I em thinking of switching my mcx to a external waste gate i think it will make it spool up way faster. But i will keep you guys posted on how the kit works because im goign riding with it thsi weekend.
Now, thats an intercooler :Rockon: ... Lots of short charge air passes!.
On the down side, the a/f sensor is too close to the exhaust outlet, will read
lean... And , i wouldn't test hp with a Dynomite at that level!.
Imagine that torque bar breaking :o| ...
