- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
What you guys found the belt to primary sheave clearance in stock form to be? Somewhat acceptable? Same or worst then on the Apex clutch?
Stock is way far away from belt, in my opinion. Like .200"
Stock SW is a little closer, but still way too far.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Cant find a socket that fits so far. When you guys do find one that fits do you carry it on the sled in case something happens?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
What are trying to fit a socket into? More info bud.Cant find a socket that fits so far. When you guys do find one that fits do you carry it on the sled in case something happens?
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
To re-install primary bolt. 22mm socket won't fit through 911 cover sleeve.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Okay what is it like 19mm?? I can’t remember I’m not at home by shop. I took my socket and grinder it down on the outside. It was a deep I believe. So you only need to grind down around the outside. Any issues PM me.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Yea it’s like a sleeve that slides down in an the stock bolt goes through with washer.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
7/8" snap on chrome socket is what I use.
Same size as the 22mm.
Fits good inside 911 cover.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
22 mm.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Before I run after the snap-on truck I ordered 4 different kind from Amazon. Did two stores yesterday and nothing. If not grinding will be done. Figured I would need to carry this spare one in the sled in case a mishaps happens and need to remove the primary. Is that what you guys do?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Not removing primary in trail. Need a puller and clutch holder. If I get to that point my buddy will tow me in. Trail side wrenching is not something I do unless it will get me home but major repairs or pulling a clutch that’s done in the heated trailer/garage on a stand. So no I do not carry this socket on trail.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Ok makes sense.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
There are many sockets that fit. Most are 12 point thin wall sockets and fit perfect. Snap-on and cheap sockets work.
- 12K
